What kind of PC are you running?
#31
I have two macs...
iBook G4
PowerPC 1.33GHz
512 MB DDR RAM
ATI 9550 32MB
30GB Hard Drive
Combo Drive
Mac OS X 10.4.5
iMac G5 w/ iSight
PowerPC 1.9GHz 64-bit
1.5GBs DDR2 RAM
ATI x600 128MB
160GB Hard Drive
Dual-Layer DVD Burner
H/K Soundsticks II
Mac OS X 10.4.5
I used to have two windows pc's....my mom got both of them...
iBook G4
PowerPC 1.33GHz
512 MB DDR RAM
ATI 9550 32MB
30GB Hard Drive
Combo Drive
Mac OS X 10.4.5
iMac G5 w/ iSight
1.5GBs DDR2 RAM
ATI x600 128MB
160GB Hard Drive
H/K Soundsticks II
Mac OS X 10.4.5
#32
i have got so many computers laying around but this is my baby
INTEL KILLER SPECS:
amd 64 3000+ newcastle core overclocked from a 2.0 to a 3.0 ghz
msi k8tneo motherboard
1 gig pc3200 mem
2 200 gig seta rapter hard drives running raid 0
ati radeon 9800 pro 256 overclocked
2 dvd burners
huge server case
water cooler for processor, vid, chipset, and hard drives
550 watt pwer supply
NOT A SINGLE FAN IN THE WHOLE PC!!, SILENT! (u can hear water trickle tho)
my question to chrono is, do u run ur water cooler off of your power supply? i run mine off a sep power plug that i built up. my whole cooler is custom made and actually uses a tranny cooler off of a honda so i could hold alot of water. then i set it up so i could turn the water cooler on when the computer turns on, but the pump actually has its own plug in which i mounted in 2 pci slots so you cant tell that it is a wack job on the inside
then i a have my laptop:
hp pavilion zv5000
amd 3000+ newcastle core (exact same processor as in the intel killer)
512 ram single stick (was going to upgrade, but i dont need to this things fast!)
40 gig hard drive
128mb ati vid
wireless
15.4 monitor
this thing is super super fast, but sucks up electricity. i really think my laptop would BURN most of the intels it meets
Matt
INTEL KILLER SPECS:
1 gig pc3200 mem
2 dvd burners
huge server case
hp pavilion zv5000
40 gig hard drive
128mb ati vid
wireless
15.4 monitor
Matt
#33
for my pump, it just runs out the back to a plug for now. i have a expansion bay relay on order, waiting for it to be in stock. on yours, youve got your tranny cooler, all ive got is my 80 mm radiator, but ive got a big aluminum resivoure, it holds 3/4 of a gallon, so that takes car of that
#35
#36
we got a new one this week
athlon 64 3200+
1 gig dual channel DDR
Asus A8N-SLI deluxe MB
250 gig sata Maxtor HDD
Antec Sonata II case
X1600 pro 256 meg video
17'' samsung 740N lcd
LG dvd-rom/cd-rw combo
80 gig maxtor that was in the old piece of *****
new speakers are on the way
athlon 64 3200+
#37
Desktop system (daily useage, gameing):
-2x AMD Opteron 246s (Roughtly equivilant to 3700+s)
-Tyan Thunder s2885 motherboard
-2gb Registered ECC PC3200 RAM
-2x 80gb 8mb 7200rpm WD drives in RAID-0 useing SATA adapters
-GeForce 6800GT 256mb @ Ultra speeds
-PCI GeForce2 (to run third monitor)
-Lite-On DLDVD+-RW
-More cooling fans then I care to count
-530w Antec power supply
-WinXP Pro
-1x 21", 2x 19" monitors
HTPC (Home Theater PC, used for recording/watching TV shows and pirating DVDs):
-AMD Athlon 1.67GHz @ 2GHz
-iWill XP333-R
-512mb PC3200
-40gb 7200rpm WD drive - boot drive
-2x100gb 7200rpm WD drives - RAID 0 - data storeage
-160gb 8mb 7200rpm WD Drive - more data storage
-WinXP Pro
Fileserver (simply sits in the corner and hosts files on my network, and runns my FTP server/BT client)
-2x P3 500MHz, 512k cache each
-512mb ECC PC133
-40gb 7200rpm - boot drive
-80gb 5400rpm - MP3 drive (almost full)
-80gb 7200rpm - Data drive
-120gb 7200rpm - data drive
-WinXP Pro
There's also a couple of laptops that I have laying around the house for general useage
-Lite-On DLDVD+-RW
-WinXP Pro
-iWill XP333-R
-512mb PC3200
-WinXP Pro
-512mb ECC PC133
-WinXP Pro
#38
#39
I don't JUST do gaming, I also do some video and photo work, but generally I do a crapload of stuff all at the same time. Lots and lots of multi-tasking (hence having three monitors), and you just can't beat the buttery smoothness of multi-tasking on a duallie with lots of RAM.
Also, I got the parts used for dirt cheap. I got the procs, mobo, RAM, coolers, and PWS for $450 (retail at the time was over $1400). That mobo alone goes for $400 new.
#41
#43
1leg
01-07-2017 01:18 PM
