what does the automatic modulator valve do?
Old Mar 4, 2006 | 07:08 PM
Yogi-96blazer's Avatar
Yogi-96blazer
I was going to look it up to see what it was but fliping through lmc I seen one, now tell me what does it do ? cause the line that is on mine that runs to the carb aint very good. I was fooling with it and it feel off, I was going to get some hose and replace it, I wanted to knwo if it had anything to do with the shifting of the truck cause it seems to not shift like it should.
on the same note, at what MPH does your inline 300 auto truck shift at?
Old Mar 4, 2006 | 10:58 PM
minishtr's Avatar
minishtr
The modulator valve shifts the trany.It works off of vacume when they go bad tranny fluid will get sucked up into the line.
Old Mar 5, 2006 | 07:06 AM
Yogi-96blazer
oh ok, so it would be inportant that that line be a snug fit on both ends, tranny end and carb end,. its pretty mycn barly one right now. Think I will try to fix it.
Old Mar 5, 2006 | 07:21 AM
kotzy's Avatar
kotzy
The modulator is used instead of linkage to the carburator to regulate what is
referred to as throttle or TV pressure. This and the govenor control
control the shift points (up and down). No doubt used because it
is easier and cheaer than linkage. Put new vaccuum hose on it if it
needs it.
Old Mar 5, 2006 | 07:48 AM
Yogi-96blazer
needs it.
alright thanks
jborushko
Jul 5, 2013 04:44 PM
GoodwinFord
2004 - 2008 F150
Nov 17, 2012 09:26 PM
RDC F250 7.3
Feb 24, 2012 09:58 PM
sawtooth
6.4L Power Stroke Diesel
Oct 16, 2009 07:43 AM
tholt34
Dec 14, 2006 08:19 PM
