AIH plug delete?
Old Mar 2, 2006 | 02:14 PM
TXsnyper's Avatar
TXsnyper
Question AIH plug delete?
I want to do the AIH plug delete, but don't know what size cap/screw I need to plug it with. ANY HELP?
Also, where do the wires go after it's been plugged?
Old Mar 2, 2006 | 02:26 PM
clux's Avatar
clux
Go to an auto parts store, tell them you need an oil pan plug for dodge with the 5.9l diesel.
Here's some directions.http://www.dieselsite.com/index.asp?...PROD&ProdID=48
Old Mar 2, 2006 | 02:30 PM
stockernavstar's Avatar
stockernavstar
A cummins drain plug will work off the dodges. Just take in your aih to match it up as there is two different ones. $8.00 is a round about figure.
the power (wire that goes from realy to aih) and ground wires can come off (wire that goes from aih to top of engine), but hook up your blue wire back to the terminal
Felt pretty wierd walking into a dodge dealership to get the drain plug.
Old Mar 2, 2006 | 03:37 PM
TXsnyper's Avatar
TXsnyper
Stay away from those Dodge dealers they'll tell ya lies.
Should I get a drain plug from a newer dodge or older dodge?
I just came from Napa they said older dodges are english, and newer ones are metric. Which do I need?
Kind of an off note, but: What size is the id on the map sensor line?
Old Mar 2, 2006 | 04:08 PM
clux's Avatar
clux
19mm plug.
I'm pretty sure the map line is 1/4".
Old Mar 2, 2006 | 08:25 PM
aklim's Avatar
aklim
Mine was a 22, IIRC
Old Mar 2, 2006 | 08:37 PM
sgrol's Avatar
sgrol
I just cut the heater off with a recip saw and put the AIH back in minus the part that impedes air flow. Worked great and is free. Got the idea from this forum, thanks to whoever suggested it.
edit: left the ground wire on and completely removed the hot wire.
Old Mar 2, 2006 | 09:07 PM
DaveWilliams's Avatar
DaveWilliams
No Codes?
The "chopping off "of the blocking part sounds like the cheap way to go, but wouldn't there be a bigger chance of having the "service engine soon" light come on after this, since the heating element was what got chopped? Just trying to make sure it will be Ok....
Old Mar 2, 2006 | 11:33 PM
jtharvey's Avatar
jtharvey
No. Loosing your AIH will not trigger the SES light. It well put a code in the computer, but it doesn't hurt performance or set the SES light.
Old Mar 2, 2006 | 11:42 PM
Kwikkordead's Avatar
Kwikkordead
I cut mine off as well. Disconnected the big wire from the relay so it would not short out. Done.
Old Mar 3, 2006 | 06:26 AM
DaveWilliams
Smile Weekend project
Well I guess this will be another checkmark on the list of mods done! Thanks for all the great advice....Hey Kwik.......Steliacoom WA was fun while it lasted...The Air Force finally let me retire....Dave
Absolute
Jan 20, 2016 02:15 PM
johnwassink
Apr 27, 2014 09:00 PM
Loadre
Ford Truck Parts for Sale
Mar 25, 2014 05:21 PM
mybigredford
30
Jun 2, 2010 12:30 PM
Pocket
45
Oct 24, 2008 08:08 PM
