AIH delete questions
Old Apr 27, 2014 | 03:25 PM
johnwassink's Avatar
johnwassink
I installed the plug from riffraff and was wondering what to do w/ the wires going to the relay that come off the main wiring harness (or whatever you call it).
Thanks
-John
Old Apr 27, 2014 | 07:41 PM
Lambert01's Avatar
Lambert01
If you live in a smog state, then save them. You may have to reinstall it.
Old Apr 27, 2014 | 07:46 PM
johnwassink
I am saving it but do i keep the wires hooked up to the relay and just take the red out that goes from relay to Aih plug..if i take the relay off the theres four wires just chillin there that u cant remove unless u start stripping the main wiring harness
Old Apr 27, 2014 | 07:52 PM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
I pressed the easy button and bought a harness for the purpose, but you can make one. Click here for info.
Edit: PDF for Dfuser install
Old Apr 27, 2014 | 08:15 PM
woodnthings's Avatar
woodnthings
Just remove the wire from the relay and remove the ground wire to the drivers side head.
Old Apr 27, 2014 | 08:35 PM
johnwassink
K sounds good ken, it does throw a soft code which i don't care about, but i read dieselsite website that disconnecting the blue wire won't allow you to do a full contribution test....interesting
http://www.dieselsite.com/airintakeheaterplug.aspx
Old Apr 27, 2014 | 09:00 PM
woodnthings
Yes, you will always get a AIH code when you pull them. No big deal though
friskyjake
Mar 21, 2017 03:34 PM
mknapik
Jan 10, 2014 09:59 PM
blustang6614
Mar 29, 2013 09:14 PM
Lifted94XLT
Kansas Chapter
30
Feb 29, 2004 12:45 AM
