Bronco II Ford Bronco II
Torque/Tranny ?
Old Jan 10, 2007 | 04:12 PM
SShank42's Avatar
SShank42
Having OD problems again. Shifts into OD but the torque will not lock/unluck whichever it take to make the rpms drop. I have not crawled underneath yet to check anything. I am going to assume it an electrical problem. If all wire and connections look good what do I do. Does the computer tell the torque to lock and unlock? What wires would I check coming off the computer to see if it sending a signal and how would I do it? Thanks
Old Jan 10, 2007 | 07:41 PM
kernel-panic's Avatar
kernel-panic
Hmmm. I'm wondering if your torque converter is also messed up. I just noticed that this thread re-surfaced, and yes, on the A4LD autos, the computer does control the transmission, or at least overdrive. The computer shouldn't have fried already again, but you may have (a) bad solenoid(s), etc. I would check autozone.com's repair guide / troubleshooting guide.
Old Jan 11, 2007 | 07:16 AM
SShank42's Avatar
SShank42
Back when this first happened (2-25-06) the torque, solenoids, and speed sensor was replace with new. None of that fixed the problem, that is when I put the computer in.
Old Jan 11, 2007 | 10:17 AM
sailorjohn's Avatar
sailorjohn
You said you got the comp cheap. Was it used or damaged?
Old Jan 11, 2007 | 12:34 PM
SShank42's Avatar
SShank42
Yes, it was used. It was 5 bucks. After I found out that fixed the problem I bought a new one.
bobbyjp
Feb 28, 2009 07:36 AM
bryonbaccus
Oct 16, 2007 12:04 AM
ryno311
May 6, 2007 10:08 PM
joe2
Aerostar
Nov 20, 2004 10:04 AM
matttt74
Apr 13, 2004 09:52 AM
