Overdrive button
Old Apr 30, 2007 | 11:34 PM
ryno311's Avatar
ryno311
Overdrive button
I have a 1998 Expedition and my switch on the column that controls the overdrive stopped working. Has anyone had this same problem? If so, what remedied the problem?
I have no other tranny problems other then the button not working. Drives fine at 125,--- miles.
Old May 1, 2007 | 08:06 AM
wchain's Avatar
wchain
ARe you sure the light isnt just burned out for the "Off" illumination?
On my 95 F150, the OD button stopped working, and I went to the dealer, picked up a new "Collar" at the end of the shifter and a new button, for less than 50 bucks. Takes around 5 minutes to put in, (plus adult beverage consumption of course)
Old May 1, 2007 | 12:28 PM
ryno311's Avatar
ryno311
I am pretty sure that it is just not the light. Whenever I push the button, there is no response. No light, no shift out of O/D.
Old May 1, 2007 | 05:50 PM
amm888's Avatar
amm888
you prob already know this, but i'm just covering the bases: you'll only notice a difference with o/d on/off when you're driving over ~40 (or whenever it is that o/d kicks in).
Old May 1, 2007 | 08:58 PM
ryno311's Avatar
ryno311
Yeah. It hasn't worked in a year or so and I have not really checked into it a whole lot because I do not pull trailers all that often. I would have assumed that at least someone reading this forum would have ran into this same problem!
Old May 1, 2007 | 09:28 PM
ford390gashog's Avatar
ford390gashog
there is a wire in the shifter that is prone to breaking its right where the shifter attaches to the column. I think it is an orange wire.
Old May 6, 2007 | 05:28 PM
MazdaRangerGuyInSTL's Avatar
MazdaRangerGuyInSTL
There are two TINY wires going to the button, through the shifter lever assembly. They are mounted to a small plastic bracket on top of the column, under the cover. This is where they like to break. You'll notice the replacement shifter level wires are a little bit longer between the lever and this bracket.
Not a big deal to replace... remove the column covers, unplug the wires, pop the bracket loose, tap out the pin and slide the lever off.
Good luck.
Old May 6, 2007 | 10:08 PM
ryno311's Avatar
ryno311
I will have to check into that. Thanks for the help. It is much appreciated!
campbell99
Oct 28, 2023 08:42 AM
slasherman3
Feb 27, 2011 11:59 AM
jimbo beam
Oct 14, 2006 09:09 AM
SC98Lariat
1997 - 2003 F150
Mar 29, 2002 02:32 AM
