Aerostar Ford Aerostar
Power Steering Fluid Loss
Old Feb 24, 2006 | 08:39 PM
vdborn's Avatar
vdborn
Unhappy Power Steering Fluid Loss
I've got a 93 Aerostar with a 4.0 litre engine. I'm losing power steering fluid but I do not see any signs of a leak under the van. I do not know if it is my imagination, but it seems like the drivers side steering gear boot is getting larger. Does the power steering fluid pass through that unit, and if so, could the return hose from that unit be plugged? I am putting fluid in the resevoir daily. This has really got me stumped. I got the rack and pinion replaced in November 2004, so this is really frustrating.
Old Feb 24, 2006 | 10:35 PM
copper_90680's Avatar
copper_90680
Welcome to our forum
It looks like you need to replace the rack again. It has been an annual ritual for me, at the precise place you are describing. Pretty soon you'll see fluid coming out the boot.
You need to flush the whole system and put in an in-line filter if you want this thing to last, or you'll keep having to replace them. The rebuilt units are real junk, and there is a reason they come with a "lifetime guarantee."
Old Feb 25, 2006 | 04:27 AM
96_4wdr's Avatar
96_4wdr
check front shocks, bushings, tie rod ends and suspension arms for any loose worn parts....check front tires for out of balance...vibration and worn shocks kill new steering units
if there is any side pull in steering, get aligned...adds extra stress on rack
is this vehicle used in town delivery low speed turning mainly or driven on rough gravel roads mainly?....rack/pinions should last 200k plus with just freeway type driving
curbing is death on rack units...women drivers pay for the expensive hobbies of owners of front end shops-fishing junkets to New Zealand, weekend vintage Ferrari racing events, big boy toy F350 570 ci stroker V8 4wdr monster mudder logging road racers at 1 mpg
i came with a "lifetime guarantee" but my wife is trying to collect early
anyone recall the original warranty period on their Aero? think mine was 3 years, Ford engineers knew how to build vehicles then
Old Feb 25, 2006 | 07:44 AM
vdborn's Avatar
vdborn
Checked with my local Canadian Tire and the unit is indeed covered under a life time warranty. It's still going to cost me 3 hours labour, plus fluid, plus front end alignment....
Thanks for pointing me in the right direction. I was going to go to another shop so you saved me the price of a new unit.
Old Feb 26, 2006 | 01:19 AM
xlt4wd90's Avatar
xlt4wd90
Strangely, you might be better off pulling a used one off of a van in the salvage yard. I have heard about how bad those rebuilt racks are. But if you can find a non-leaking rack in a salvage yard, its seals are probably going to work better than those rebuilts.
I am currently using a rack that I installed about 14 years ago. It was 2 years used when I got it from the salvage yard.
Old Feb 26, 2006 | 09:02 AM
ken1mod's Avatar
ken1mod
First, you might try adding stp oil treatment to the system. I have used this many times on leaky racks and have always had good resultts. what do you have to lose? You might also consider replacing the rack seals while the unit is on the truck. I would try this as it is only about 20 bucks for the seal kit.
ken
Old Mar 2, 2006 | 12:57 AM
93nighthawk's Avatar
93nighthawk
Welcome!
How are the steering rack repairs going?
Old Mar 2, 2006 | 05:14 PM
vdborn's Avatar
vdborn
They replaced the rack and pinion and I haven't lost a drop for the 1st 100 miles. Thanks for asking. They took a knife to the boot and it was just full of gunk.
Mike Stuckey
Nov 17, 2016 11:12 AM
mattymax
Oct 16, 2016 04:15 PM
Scott Yager
May 8, 2016 09:02 PM
abyars111
Apr 16, 2013 05:36 PM
wicat3
15
Sep 24, 2012 06:20 PM
