RPMs @ 55 MPH
Old Feb 23, 2006 | 07:36 PM
brosko80's Avatar
brosko80
RPMs @ 55 MPH
at 55 mile per hour what should the rpms be for a 88 f 150 2wd with the 300 inline six 3.55 gears and 235 75 r 15 tires. mine is at almost 2100 at 55 mph and someone told me that this is way to high.
just wondering.
Old Feb 23, 2006 | 08:25 PM
brosko80's Avatar
brosko80
anybody have any idea?
Old Feb 23, 2006 | 08:27 PM
amish77's Avatar
amish77
hold on a sec, I gotta do some math
Old Feb 23, 2006 | 08:28 PM
Thomasm67's Avatar
Thomasm67
Are you running an auto or 4 spd or 5 spd?
Old Feb 23, 2006 | 08:29 PM
Mark Wenner's Avatar
Mark Wenner
I'm thinking if you don't have an overdrive tranny that probably sounds about right.
Old Feb 23, 2006 | 08:32 PM
brosko80's Avatar
brosko80
its the mazda m5od, which is an over drive tranny.
Old Feb 23, 2006 | 08:44 PM
amish77's Avatar
amish77
ok, I'm assuming you have an overdrive tranny, so yes that's fine. Here's the math I did if you (or somebody else) wants to check it.
235mm wide tire, 75% of that is 176.25 mm, is 6.93898'' total sidewall, is 21.939'' total tire height
21.939*pie gives us circumference (roughly as tread is a factor here) which is 68.9233'', so every revolution of the tire traverses 69'', or 5.74361'.
So you're going 55MPH, or 290400ft/hr, so divide that by the ft/rev, and you get 505060.5rev/hr. Divide this by 60 and you get 842.676 rev/min. Now your final drive gear. 842.676*3.55 is 2991.5 RPM.
This assumes a final drive out of the tranny of 1:1, but still seems a bit high to me. Anyways, you've got overdrive if I'm right, and you're fine.
Old Feb 23, 2006 | 08:45 PM
amish77's Avatar
amish77
oh, and your overdrive would have about a .7 to one drive ratio, which also seems right as far as trannies go.
Old Feb 23, 2006 | 08:48 PM
Mark Wenner
I've got the same tranny, gearing and tires on my Bronco, and now that I think about it I believe I'm turning about 2800 or so at 75 mph. If that's right (my memory for things like this isn't as good as it used to be, or maybe I just don't pay that much attention anymore) then you're in the right range. The overdrive on the M5OD is .8, at least on mine.
Old Feb 23, 2006 | 08:53 PM
amish77's Avatar
amish77
sweet, thanks mark.
brosko80's Avatar
brosko80
thats about what mine is at 75. i guess im "normal" then thanks guys
and thanks amish for all that math work. pretty technical!
Old Feb 23, 2006 | 09:04 PM
amish77's Avatar
amish77
nah it's nothing, just basic geometry. The only thing you've gotta know is how tires are set up.
Old Feb 24, 2006 | 07:30 AM
Mauler's Avatar
Mauler
Just a little correction on the tire diameter: Sidewall height is 6.939", multiply by 2 (top and bottom), plus the 15" wheel gives a diameter (tire height) of 28.88".
1:1 transmission ratio output puts engine RPM's at 2278.
5th gear (using 0.8 to 1) is 1822 RPM's.
Old Feb 24, 2006 | 08:28 AM
amish77's Avatar
amish77
ah, and therein lies mine being high. Thanks mauler. I thought I might be a little off. It just seemed high.
But then again 7'' of sidewall seemed a bit much for me so that's why I thought it was total sidewall. thanks again.
JstoneF150
2004 - 2008 F150
Feb 19, 2015 08:57 AM
wotan
Oct 30, 2013 09:52 PM
six6six
Jul 30, 2011 10:39 PM
chadstar
2004 - 2008 F150
Sep 25, 2006 09:14 PM
