When was the last time you had your spark plugs changed? Any check engine light?
Mine did that too at 45 MPH, when it locked into OD. It was a misfire. Plugs were shot. Had them replaced and it has been running perfect for over 20k miles
Your spark plugs are dying. Get them changed now. Until then, don't let the engine be under load at low RPM. Kick the pedal down and force a downshift. If you let the truck start jerking, you're going to cause other issues.
