1978 - 1996 Big Bronco
Idle issues.
Old Feb 22, 2006 | 10:34 PM
sm_pacman's Avatar
sm_pacman
Idle issues.
I know I can count on you guys to help me figure this out. Here's my issue, my 96 EB Bronco (351W w/138,000) idles a little rough, more like it lopes. Feels almost like the timing is off and it is going to die, but it doesn't. Runs fine on the road, but idles rough at stops. Had the IAC crap a few months back but solved it with a tune-up in which I replaced the plugs, wires, cap, rotor, IAC and TPS. replaced the S-belt a little more than a week ago, when it started tearing during a long drive. I didn't have any idle issues then, but in the last 4-5 days it has had the rough, loping idle. I don't believe it is the timing, because I checked it this evening and the "base" timing is at 10' BTDC. Any ideas guys. oh yeah, no codes showing either.
Old Feb 23, 2006 | 08:04 AM
Streetgang's Avatar
Streetgang
I dont want sound stupid, but I have to ask......did you remove the SPOUT when you checked/set the timing?
Old Feb 23, 2006 | 08:22 AM
sm_pacman's Avatar
sm_pacman
no stupid question, but yes. I figured the base timing might be off a little, but it was right at 10'.
Old Feb 23, 2006 | 08:39 AM
Streetgang's Avatar
Streetgang
and you did check for codes, or are we just going by the fact that the CEL is not lit, so there should be no codes theory????
Have you taken a look at what your fuel pressure is at the rail? When was the last time the fuel filter was replaced?
I dont know....these are the first few things that come to mind....?
Old Feb 23, 2006 | 10:21 AM
BillyBob69's Avatar
BillyBob69
Clogged cat?
Old Feb 28, 2006 | 09:03 PM
thenewjohndeere's Avatar
thenewjohndeere
I had a similar issue on my 91 302. It was a random idler and we couldnt figure it out. Brought it to some different shops they couldnt figure it out. Decided to take it to one of my buddys family garage in south carolina and those good ol boys figured it out. Ended up being the harmonic balancer had broken loose. Dont know if thats your problem, but it sounds like some of same problems i was haveing ... thats my 2 cents
Old Mar 1, 2006 | 09:01 AM
sm_pacman's Avatar
sm_pacman
ok guys, checked vacuum lines, IAC & EGR valve, no issues. Went back and checked for codes again and got 3; P0401,P1131, P1151. Streetgang, I know what you're going to say, I told you so, so let me have it. I know the code definitions, and I'm assuming I just need to replace the O2 sensors, but the P0401 I'm not sure about. Does it relate to the O2 sensors and how exhaust gas is sent back to the system? I don't want to spend $150+ on O2 sensors to find out it's some other problem. Thanks again guys.
Old Apr 12, 2006 | 12:13 PM
felix1995's Avatar
felix1995
I am having the same problem, I replace EGR valve, and I got error code P1131 insuff. Switching 02 Bank 1 sensor 1 sensor/lean. also when i drive my 95 ford ranger 2.3L I can't go pass 60 mile/hour. i start to loose power. what is the problem
Old Apr 12, 2006 | 12:19 PM
blackened's Avatar
blackened
usually you can just clean the o2 sensors without having to buy new ones, with some throttle body cleaner. they don't really just go out that often.
Chief Many Inches
Jan 4, 2015 05:43 PM
Trombogon
Missouri Chapter
May 10, 2014 08:15 AM
teamshadyinc
49
Oct 20, 2013 05:58 PM
Ctkallday666
13
Jul 10, 2013 07:54 AM
cr_expyeb98
1997 - 2003 F150
Sep 15, 2006 08:34 PM
