Sponsored by: Kumho
truck pulls to left when braking
Old Feb 21, 2006 | 08:05 PM
fordinmudd's Avatar
fordinmudd
when I put my foot on the brake pedal my truck pulls to the left.This truck is an 88 f 350 4x4..both front calipers are new but I notice that the front passenger side rotor is pitted pretty bad would that have anything to do with it?
Old Feb 21, 2006 | 10:08 PM
thesprocket26's Avatar
thesprocket26
If you rotors are groved or pitted I would start there. Did you correctly bleed the brake system?
Old Feb 22, 2006 | 02:58 AM
460's Avatar
460
And if it is properly bled, are your brake hoses in good condition? A bad hose at the wheel would cause it to pull to one side.
Old Feb 22, 2006 | 08:19 AM
jtmerritt's Avatar
jtmerritt
Also if your left rear brake is grabbing that will cause the truck to pull to the left as well.
John
Old Feb 22, 2006 | 09:35 AM
grease monkey's Avatar
grease monkey
A sticking piston or caliper slide pins can be the problem too.
Capt.Schenk
Feb 9, 2024 07:57 AM
Norma stitz
Oct 29, 2016 09:20 AM
Rkgfire
Jul 21, 2015 11:06 PM
Rino Onir
Feb 8, 2011 10:56 PM
Bertha1
Oct 17, 2006 04:07 PM
