New carb...........
Old Apr 26, 2001 | 02:55 PM
tamwill's Avatar
tamwill
New carb...........
Hey all, I just installed my new Edelbrock 1405 and if I hit the gas sharply, it either cuts out for a split-second or backfires through the carb. What gives? Thanks in advance. Bill
'70 F-250 Camper Special 360/C-6, 3.73, 8 mpg uphill or down
Old Apr 26, 2001 | 03:07 PM
BB's Avatar
BB
New carb...........
As long as the accelerator pump is working properly, your either too lean or have a vacuum leak.
Barry
Old Apr 26, 2001 | 08:47 PM
Franklin2's Avatar
Franklin2
New carb...........
Advance the timing a little.
Old Apr 26, 2001 | 09:17 PM
GWB's Avatar
GWB
New carb...........
On my new rebuilt motor, install a 4 and every now and again it would pop back thur carb, it has a duel vaccum dist and points, thought it might be old points in so change them to petronic (unsure of spelling) Run a whole lot better but again every now and again pop thur carb, So check one of my vaccum line and it had a broken fuse in it about a inch up in side, just the end of fuse, and the other vaccum line would bleed down with hand held vaccum pump so replace that also, then spray a little carb cleaner in carb and and it ran out the base of carb so replace them, one on intake and one on top of 2 in. adjusted timing again and now things seem to be on the right track again. hope it helps some
GWB
Old Apr 26, 2001 | 10:51 PM
GWB's Avatar
GWB
New carb...........
ColtonMullis
Apr 30, 2014 08:47 PM
sweetlou1
17
Mar 17, 2013 08:18 PM
Ranger73
Jan 13, 2007 01:17 PM
88bronco351
Bronco II
Oct 30, 2003 10:57 PM
jeepin
Jul 10, 2003 06:58 AM
