Shifting Problems
Old Apr 26, 2001 | 02:16 PM
oddballfords's Avatar
oddballfords
Shifting Problems
Old Apr 26, 2001 | 09:15 PM
dwheater's Avatar
dwheater
Shifting Problems
F100 won't shift automatically. Shifts fine manually. I have replaced the modulator and filter, checked vacuum line, changed fluid. I recently had the carb changed, I was told the kickdown does not need to be hooked up, I am curious if this could be the problem.
Old Apr 26, 2001 | 10:09 PM
1971camperspecial's Avatar
1971camperspecial
Shifting Problems
Try looking at your tranny linkage. Look and see if it is wobbled out. Thats the problem with mine.
Old Apr 26, 2001 | 10:51 PM
GWB's Avatar
GWB
Shifting Problems
Take the kickdown and shove it the other way and try it, or should I say lever, had to take mine off would not shift right, that is the linkage itself. GWB
Old Apr 27, 2001 | 01:07 AM
dwheater's Avatar
dwheater
Shifting Problems
Checked linkage everything looks okay. Still not shifting.
Don
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
