When To replace CARB???
Old Jul 10, 2003 | 03:21 AM
jeepin's Avatar
jeepin
WHat are the symptoms that tell you its time for a new carb??? and what kind should I get???
Old Jul 10, 2003 | 06:58 AM
Caddy 53's Avatar
Caddy 53
Jeepin: I know that many on this site like edlebrock but I a am on old Holley man. Your truck came from factory w/. 4180 holley My exp. has been that a rebuild is good as long as not excessive wear in the throttle shaft area. This carb is basically a 4160 but with EPA mod's from factory.Many adj.have been removed or CASTED over (HIDDEN). IF you Want to replace w holley buy a 4160 w/same jet,pump,acc pump nozzel, cam profile ETC. 600 cfm
Ford used a searies of three base gaskets and alum.heat shield and I never found anybody to make gaskets that would hold up except FORD. I had the same setup and tried a lot of things for increaed perf and better gas mileage To me it was a dissappointment. This eng comb is realiable but it loves gas (11) and a 4.3 gm will make it strain to stay ahead. The newer efi 5.8 is better but the competion will whip it also.
I know I have many fellow FTE people that won't agree ,but LOOK outside the box ,so to speak, The performance won't match a 350.
THIS post will probably irritate some but many other's as well as myseff HAVE BEEN THERE>
GOOD luck on your Holley and its future.
caddy 53 chuck I think I may have orig part # on gasket from ford but they will have to order.
special blue
1978 - 1996 Big Bronco
Jan 15, 2013 11:17 AM
dmc919
Sep 9, 2004 07:37 AM
dcexplorer
Nov 23, 2003 08:09 PM
jeepin
Aug 12, 2003 02:22 PM
David
19
Jan 29, 2000 08:01 PM
