65 F100 4x4 drive train upgrades
Looking for info on possible upgrades. I want to stay with the factory frame and just got a high pinion D44 disk brake front end with five lug outers set up for leafs like I have. I plan to install that with a later brake cyl and booster. Wondering what options I'd have to swap to a different tranny and T-case with the factory engine mounts I have. It's a divorced T-case and its got the early single front mount and rear bellhousing mounts. Would any type of auto tranny be available with a married t-case? Would the later married T-case mount fit the frame or would that put to much weight onto the older single front engine mount?
No auto tranny will have the mounts on the bellhousing that you need.
As for direct bolt in manual transmissions, you're stuck with the NP435. With a little fab work, you could swap in an NV4500 or a Clark 5 speed or pretty much any tranny with a long enough input shaft and short enough case.
If you wanted, you could find a later NP435 and married t-case setup and swap some of the tranny shafts around to make it bolt into your pickup if you don't like the divorced setup for some reason.
Here's a thought, has anyone ever boxed the front of one of these earlier frames and used the later style engine perches? Sounds like a lot of work and perhaps my factory 352 doesn't have the mounts in the side?
Bummer really? I've got the axle already to and was looking forward to the brake upgrade. Can the tranny crossmember be modified to work? Is there a different style from a later divorced type that would have teh clearance and work?
No, I have not done my transfer case swap to the NP205 yet...lol. Soon. The GV overdrive is so light I don't think the TC will notice it back there. Then it's just a matter of driveshaft.
Lower pic: 1965/66 F100/250 2WD - 1966 F100 4WD - 1967/72 F100/250 2WD/4WD & F350.
Not sure if you'd agree, but I think if a person went to a married transfer case then they would probably have to fashion some sort of support for it or the transmission. The transmission is already hanging out in space beyond the bell housing and tacking on a married transfer case without any additional support seems like it would be a ton of weight hanging back there.
If I were to switch to a married setup**, I would build a cross member to go under the tranny/t-case adapter. Whether or not it is needed, (it's a good idea either way) I don't know - I just like to build.
** Never, ever going to happen
1965 F100/250 4WD - 1965/66 F350 - 1966 F250 4WD uses the same engine mounting system as 1961/64 F100/700, but I did not say that the parts were the same.
Compare the front engine mounting system for 1964 in upper pic with these 1965/66's in lower (upper) pic.
Both have a bracket that bolts to the front of the engine with upper and lower center rubber insulators.
I didn't post the rear engine mounting system pic for the 1964 (I will if asked), but it's similar to the 1965/66's shown in pic, as the bell housing (7505) has two "ears."
There's one rubber insulator per side below the cross member, one rubber insulator per side above the cross member, below the ears of the bell housing.
Sorry ND. Yes, I see what you mean that they are similar in where they mount however, the 64 does not have the horseshoe type mount on bell housing, unless of course the set I took out and replace with new ones are all wrong? Anyway your point of where they mount (3 points) is understood. The other unknown (referring to the context of original discussion) is how close the 352 oil pan might be to the Dana 44 High Pinion if installed.
ND would you have a shot of the original 65 F100 4x4 pan for a 352? I suspect my engine was swapped in the early 70's but the truck did originally come with a 352 so it may be the original pan.
tyheid2002
12-07-2005 10:52 AM
