Driver Side Passenger Power Window Switch
Old Feb 18, 2006 | 07:52 PM
Randy Page's Avatar
Randy Page
Got a 1997 F 150
The Driver Side Passenger Power Window Switch Does Not Work and I don't have a clue the best way to trouble shoot this one.
I could really use some detailed help on the best way to troubleshoot this one.
The double throw switches and the wiring diagram have me stumped.
Thanks in advance for the help.
Old Feb 19, 2006 | 04:22 PM
Franklin2's Avatar
Franklin2
I assume the driver's side switch works the passenger side window? If it does, that means the motor is ok in the pass side window, and the only thing left would be the passenger side switch being bad.
What may have you stumped is the way they have the switches wired. If you notice, there is not ground or hot wire going to the motor. There are two leads to the motor, and the crazy wiring at the switches reverses the polarity of these motor wires, making the motor change directions.
Old Feb 19, 2006 | 05:07 PM
Randy Page's Avatar
Randy Page
The passenger side switch works fine.
Its the driver side switch for the passenger window.
I pulled the switch and check continuity across the leads.
There are 2 LED which I didn't bother to check.
Touching one probe to the _ terminal the polarity changes on the 2 other terminals when I press the switch. Whether I press the up or the down the polarity changes.
So I'm guessing the switch is doing its job.
A broken wire? How wouls I know for sure before I start chasing wires under the dash?
Thanks
Randy
Old Feb 20, 2006 | 08:08 AM
Franklin2's Avatar
Franklin2
Sorry I missed that in your first post.
Here's a diagram for a 96. If all the wire colors are the same as yours, we can assume it is the same. Look in the lower right corner of the diagram.
http://www.autozone.com/images/cds/g...3d800a3a60.gif
What I would do is pull out both switches, so you can get to the wiring. The "right" in the diagram is the passenger side. The little box down low is the passenger side switch, and the big box above that is the driver's side dual switch.
Once you have the wiring out where you can check it, I would put one of your meter leads on the driver's side door, and the other on the passenger side door, and check for continuity between the:
lightblue/black
white/yellow or yellow/black
tan/lightblue or red/black
If you study the diagram, we can make some assumptions. The lightblue/black is the hot wire that is feeding the passenger side switch. It must be ok, since the passenger side switch works. When you activate the driver's side switch for the passenger side, you should get voltage at the passenger side switch on the other two wires. Make sure you put your meter across both wires if you are going to check for voltage. The polarity will swap around, depending if you go up or down with the switch.
I hope your 97 wiring is the same as the 96.
Old Feb 21, 2006 | 11:13 PM
wassltz400's Avatar
wassltz400
Check the for corrosion on the contacts also. a little corrosion can cause hell. I had a similar problem a 93' bronco i owned. The tail gate window switch was not working. I checked the connector for the removable topper and it was a little green from going topless. Just a thought for you for when you are you looking at your wire harness(es).
TexasGuy001
Jun 11, 2016 09:44 AM
pllckjsh
2004 - 2008 F150
Aug 28, 2012 07:45 AM
kable
Electrical Systems/Wiring
Aug 23, 2004 09:44 PM
nosbor
Feb 1, 2004 12:25 AM
Mattdad1
1997 - 2003 F150
Aug 14, 2003 06:05 PM
