Goofy Blinker
Old May 3, 2001 | 10:11 PM
Nitro's Avatar
Nitro
Goofy Blinker
Hey guys,
Ok here is what is up now. I was working on my light system (77 150) and noticed that my right blinker wasnt working right, so I put in a new blinker controll (looks like a little round canister) and it fixed the first problem but I discovered another. When my lights are off my blinkers work fine in both directions but when I have either my clearance lights on or my headlights the left blinker works just as usual but the right blinker comes on very dimly and doesnt flash, it just stays lit up. I have had the whole rear end of the pickup rewired after having all of the wiring ripped out in a snowbank I tried to bust, so I know the problem isnt there. Anybody have any ideas????? Thanks for the help
Nitro
Old May 3, 2001 | 10:39 PM
MSTRAWN's Avatar
MSTRAWN
Goofy Blinker
Sounds like a bad ground. Doesn't matter if the wiring is new or old, I would check the grounds at all sockets first.
1977 F-100
300 I-6 / C-4 (soon to be AOD)
Offy intake w/Edelbrock 500CFM
Hooker Ceramic coated headers w/duals
MSD6
Whiter whites/Brighter brights
Old May 4, 2001 | 06:09 AM
jowilker's Avatar
jowilker
Goofy Blinker
Nitro, You could have two wires touching (maybe). Your running lights are on the other filiment than the brake/signal, so the two shouldn't have anything to do with the other. As preveosly posted check your grounds. Run a battery post brush into the bulb holder. It's working so grounding is first check.
John
jowilker
[link:www.ford-trucks.net/users/jowilker|Club FTE since 01 01] My FTE Page
[link:www.ford-trucks.net/users/jowilker/NCFTE.html|NC Truck Owners] NC Ford Truck owners group
66F100s Rule
In the cool still quite of night you can hear chevies rusting away.
Old May 4, 2001 | 10:41 AM
sparky's Avatar
sparky
Goofy Blinker
Bad ground, meaning it is either missing or really corroded. The running lights are getting their ground thru the signal light circuit instead of the ground.
Check the ground tab in the sockets,front and rear, and also the ground stud which should be about 6-8 inches from the socket. The ground wire should be a black colored one.
Have Fun
Sparky
>now. I was working
>so I put in a
>lit up. I have
>I tried to bust, so
>Nitro
Old May 4, 2001 | 09:56 PM
tetraruby's Avatar
tetraruby
Goofy Blinker
Check your bulb socket. I had really intermintent problems with one of my blinkers and swore up and down it was a wiring problem. It ended up being a partially rusted connection within the socket. The replacements are cheap and readily available. -My two cents.
Old May 6, 2001 | 09:52 AM
MSTRAWN's Avatar
MSTRAWN
Goofy Blinker
Had another thought, make sure that someone has not put (forced) an 1156 bulb into a socket made for an 1157. Ran across that one on the 66 mustang. Sometimes PO's really bite.
1977 F-100
MSD6
Old May 6, 2001 | 12:55 PM
Franklin2's Avatar
Franklin2
Goofy Blinker
Here is a little diagram as to what happens when you have a bad ground in circuit with a dual filament bulbs that most American cars use. The backward current flow can find it's way through many things up front in the dash area and cause strange things to happen.
https://www.ford-trucks.com/dcforum/User_files/3af58fc535439859.gif
Old May 7, 2001 | 12:28 AM
oz9609's Avatar
oz9609
Goofy Blinker
Ditto on the ground problem. This causes a feedback of current that causes odd things to happen.
Old May 7, 2001 | 05:01 AM
greatsandy's Avatar
greatsandy
Goofy Blinker
