Do I have a bottem end knock????
Old Feb 17, 2006 | 12:24 PM
fordfan302's Avatar
fordfan302
Well just recently out of nowhere my motor seems to be knocking (rod knock i guess??) I can only hear it at idle and its loud enough to hear from inside the cab...BTW my motor just turned over to 200,000 miles, and I can't say im easy on it (i bring it up to 5,000RPMs in 2nd gear alot)
Old Feb 17, 2006 | 12:30 PM
whodat54321's Avatar
whodat54321
200K is a lot of miles on any motor. Bottom end slop can be stopped with fresh
rod bearings, but you'll have to drop the pan and check the crank to make sure those
bearings aren't shot too. 5K is a bit much if the motor has a stock cam.
did you try putting something like stp in it to see if it reduces the sound?
Old Feb 17, 2006 | 10:29 PM
Bdox's Avatar
Bdox
Change the oil. Drain it into a clean shallow pan. Slowly stir the bottom of the oil in the pan with a magnet. If you come up with any metal filings, pull the pan and inspect the bearings.
Old Feb 18, 2006 | 07:59 AM
fordfan302's Avatar
fordfan302
I guess I didnt mention...I just changed the oil, and thats when I really started hearing it...Ive heard it before but I really heard it after the oil was changed
Old Feb 18, 2006 | 08:14 AM
1964FORD4ME's Avatar
1964FORD4ME
It Sounds Like Your Rod And Main Bearings Are Worn. Be Careful You Dont Want To Knock A Hole In Your Block. A Connecting Rod Can Do Some Damage .
Old Feb 18, 2006 | 09:58 AM
Bdox's Avatar
Bdox
I would say that you need to pull the pan and get a look at those bearings.
Old Feb 18, 2006 | 10:05 AM
fordfan302's Avatar
fordfan302
Ill get another opinion on what it sounds like, and if it is, Ill just swap out the motor (I can find em real cheap)...and after that Its up For Sale
Old Feb 19, 2006 | 07:44 AM
8 Lugs's Avatar
8 Lugs
To replace bearings in a motor with 200,000 miles would be throwing good money (and labor) away!
What it needs is a rebuild!
Steve G.
Old Feb 19, 2006 | 10:37 AM
Bdox's Avatar
Bdox
Steve G.
It is likely that your are right. But it's just a little too easy to spend someone else's money when you have not examined the motor.
Old Feb 19, 2006 | 11:01 AM
fordfan302's Avatar
fordfan302
I talked to a few friends and they said that I need high mileage motor oil...You think this would make a difference???
Oh and as of now I cant hear it at all anymore
Old Feb 19, 2006 | 11:05 AM
fordfan302's Avatar
fordfan302
Steve G.
And although this is a good idea and I've been wanting to do this for a while, My pop won't let me. He doesnt want me to put any more money in it than I have to because Im trying to sell it
Old Feb 19, 2006 | 06:39 PM
8 Lugs's Avatar
8 Lugs
Not meaning to sound arrogant but;
A gasoline motor with 200,000 miles and knocks needs;
rebuilding or replacement!
Examination is not necessary!
I am not new to exploratorary motor surgery!
Steve G.
PS. High mileage motor oil for your motor is 20W50 (just a heavier weight oil)
MartyRayII
Feb 16, 2011 09:24 AM
FxRiZBeAsTLy
Dec 11, 2010 10:45 AM
FxRiZBeAsTLy
Oct 31, 2010 02:53 PM
Ranger256
Escape & Escape Hybrid
Dec 30, 2005 01:41 PM
V10 CREW
Modular V10 (6.8l)
Jan 13, 2003 11:59 AM
