Kwik air filter mod
Old Feb 20, 2006 | 04:06 PM
  #46
jtharvey's Avatar
jtharvey
Originally Posted by fcfirefighter05
is the NAPA 6637 a drop in filter or is this a different type?
Different type. Check my gallery for some pics. Also run some searches for the Kwik filter -- it's the same as the 6637.
Originally Posted by edub32
jsmahan, I believe you are hearing "surge" also since you specify that your gauge is jumping around. Surge and flutter sounds definitely aren't good though. The 6637 doesn't cause this nor does it fix it. The big filter is just letting you hear the noises and the stock airbox just muffles it. The WW will fix it most of the time but to never hear it again you'll need the ATS.
Agree with you there. Surge happens with the stock airbox, you just can't hear it, and it may be to a lesser degree. Taking your foot out of the throttle will also cure those surge issues. I'd rather have the better filtration of the 6637 and just take my foot out of it every once in a while.
Old Feb 20, 2006 | 04:23 PM
  #47
nantruckit's Avatar
nantruckit
Can somebody describe what "surge" and "flutter" sound like? Also I'd like to know what "ATS" is. I love my Kwik filter and don't think I'm hearing anything bad. I can just hear the lovely "whistle" when I get on it and the "shhhhh" of the pressure releasing when I get off it or during shifts. Sometimes the pressure release is more pronounced when I have my foot deep and let off just as it's shifting into second or third...pretty sure that's normal though...it'd better be because I'd hate to give up that sound!
Old Feb 20, 2006 | 04:24 PM
  #48
jsmahan's Avatar
jsmahan
If taking your foot out of it and running 45 mph on the interstate is the fix, I need to spend some more money. I am unable to utilize 6th gear at all while pulling the 5ver due to "surge". With the stock air box I neither hear, see or feel the "surge". The filter was the only change since last hard pull. Why have all that extra power and be unable to use it?
Old Feb 20, 2006 | 04:29 PM
  #49
edub32's Avatar
edub32
Compressor surge is usually heard when you have a big load or going up a pretty steep grade. It's kind of hard to describe online but its like SS! SS! SS! and the boost gauge like stutters up and down. It's very hard on the stock turbo. The "ATS" I'm referring to is a high performance compressor housing that you can buy for around $400 and is made by a company named ATS. Here's a link to one: http://www.dieselinnovations.com/di....products&cat=1 (it's the 3rd one down)
jsmahan, you should try a wicked wheel. It will fix the surge most of the time. And if you don't think it's good enough you can always run it along with your ATS compressor shroud. A Wicked wheel is a lot cheaper then a new turbo.
Old Feb 20, 2006 | 04:39 PM
  #50
jsmahan's Avatar
jsmahan
I had planned on the WW but at some point here I read you actually lose boost with the WW and that the stock wheel may perform better than the WW with the ATS. Just trying to eliminate the "buy this to fix problem caused by buying this". At some point things (mods) should stop causing other issues. It seems the more we throw at these things the more they need.
Old Feb 20, 2006 | 04:41 PM
  #51
edub32's Avatar
edub32
Yeah I definitely agree with your last statement. I'm running into troubles myself with my HPOP not being able to supply enough oil to the injectors (ICP code).
Old Feb 20, 2006 | 04:52 PM
  #52
jtharvey's Avatar
jtharvey
Oh wow. I didn't know it was that bad for you & I can see how that's a problem. Mine usually only does it for a few seconds. I let off of the throttle, then get right back in it a little easier and it's gone.
Now, I know you can't hear it surge the stock airbox, and I can't even feel it with the 6637 installed, but how are you seeing it? Did the needle on the boost guage bounce when it was surging, with the 6637 installed? And, I assume that the needle no longer bounces with the stock air box? I'm just trying to see if the more restrictive airbox is really causing the surge to actually stop, or just that you can't hear it.
Old Feb 20, 2006 | 04:58 PM
  #53
jsmahan's Avatar
jsmahan
Yes you can see the needle on the boost gauge bouncing in relation to the surge. Actually starts just before you hear it. With the stock box, no surge seen, heard or felt. I can feel it due to loss of power. I know isurge can cause damage to the turbo but it just seems weird that there are no signs or symptoms w/ the stock box
Old Feb 20, 2006 | 05:07 PM
  #54
fei1's Avatar
fei1
So, what amount of weight are we talking before you will get the turbo to stall(stock)? If the WW is installed will that prevent this compressor stall(up to what amount of weight can be towed before the WW will stall?)
Old Feb 20, 2006 | 05:16 PM
  #55
jsmahan's Avatar
jsmahan
Don't know about WW yet. with the stock wheel I'm towing about 12,500 and have bad problems w/ surge and the kwik filter.
Old Feb 20, 2006 | 07:10 PM
  #56
Wieckster's Avatar
Wieckster
is it true that the filter you are showing #46637 is $19.57 each? at fleetfilter I thought that filter has 70.00 maybe I was wrong Help me out here!!!!!!!
Old Feb 20, 2006 | 07:13 PM
  #57
guzzle92's Avatar
guzzle92
yes, looks like the price has gone up a little since the last time I bought a couple of them. Freight hurts a little if you only buy one. If you get more along with some fuel filters, price can't be beat.
Old Feb 20, 2006 | 07:17 PM
  #58
Wieckster's Avatar
Wieckster
Are those filters washable or do you just pitch them and put a new one on and if thats the case how often are you guys changing them ?
Old Feb 20, 2006 | 07:20 PM
  #59
guzzle92's Avatar
guzzle92
Just pitch them. I went 9 months (about 9500 mi) and it was starting to look kinda gray so I changed it. Filterminder still had not moved though.
Old Feb 20, 2006 | 07:33 PM
  #60
edub32's Avatar
edub32
The filter minder is officially garbage.
