HFCM filter, does it matter if....
Old Feb 27, 2006 | 10:48 PM
Beachbumcook's Avatar
Beachbumcook
Got Diesel?
Originally Posted by ag-ford-4x4
Does it make any difference if you put the filter in the cap and then screw it on or if you put the filter in the housing and THEN screw on the cap? My manual doesnt say, but a tech page from ford says to snap the filter into the cap, and then install, which is what i did. But there is a slit in the filter where it looks like it is supposed to seat. As i screwed it on, every turn had a hard spot in it until it got on a ways, then it was OK, which i assume was the filter seating.
Havent purged the air, need info so i can fix before it fills with fuel.
I have a 4X4 and I am unable to get the filter into the cap and re-install. I have to "baby" the HFCM filter in first and seat all the way in then screw the cap on. The filter does snap into the cap, but I am unable (with the room I have) to get the filter and cap (all in one) to slide up into the housing. Changed mine this afternoon and installed the new drain plug I bought several months back from my dealer.
Good as new and my truck started with just 1 or 2 extra rotations of the motor... have never cycled the starter on/off 3 times like some do.
O-rings just slide on and off and seat just fine in the last groove of the filter cap(s). In my haste, I did not suck out the fuel in the small engine mounted housing... just hope there wasn't anything floating in there?
Old Feb 28, 2006 | 09:44 AM
ag-ford-4x4's Avatar
ag-ford-4x4
I have no idea why you are supposed to suck out hte fuel in the housing...i did it, but i dont know why.
Old Feb 28, 2006 | 11:45 AM
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
You have to be double jointed to get the filter on the frame in and out.
Old Feb 28, 2006 | 12:30 PM
gtodalep's Avatar
gtodalep
Be sure to lube the o-ring real good or it might tear and then the truck will not run. Sucks air and leans out, no power. Personal experience here. I thought the diesel fuel that was present was enough lube, not true. Second time around I used Motor Oil and it went on with no problems. Valuable lesson! Note: I found the needed 36mm 1/2 drive socket at Sears for $6.99.
Old Feb 28, 2006 | 07:50 PM
Beachbumcook
Got Diesel?
To keep the dirt out of the fuel intake tube.
Sediment on the outside of the filter now mixed with the clean fuel when you pulled the filter out. Suck out the fuel present and hopefully any sediment goes with it. Leaving it in now mixes and will be sucked up into the injectors.
Old Apr 2, 2006 | 08:22 AM
Beachbumcook
Got Diesel?
Good weblink below...
http://www.forddoctorsdts.com/articl...icle-06-03.php
Great info on filters and fuel quality.
Good reason to check or change often or on schedule.
Use only Racor/Motorcraft or IH fuel filters and never WIX as they lack the white membrame on the HFCM filter.
Ford Fx4
Apr 1, 2014 08:19 PM
Nobby
Dec 18, 2011 09:16 PM
chunt
Oct 7, 2011 12:23 PM
wildstang
Aug 5, 2009 09:25 AM
Superdudey
Jul 5, 2007 12:01 PM
