stupid fuel filter question...
Old Jul 5, 2007 | 07:39 AM
Superdudey's Avatar
Superdudey
yesterday i changed out my filters, well who ever owned it before me stripped out the 6mm hex screw and it wont come out. When i say stripped, the hole is rounded out and the 6mm wont work anymore.
What is that for? To drain the filter housing before you take the cap off?
Old Jul 5, 2007 | 08:08 AM
satcom40's Avatar
satcom40
Yes the 6mm screw is for draining water. Get the new one went you replace it. Good luck, John
Old Jul 5, 2007 | 08:11 AM
Superdudey's Avatar
Superdudey
if i pull the cap off when pulling the filter, is pulling that plug still needed? or is that a seperate from the main housing?
Old Jul 5, 2007 | 08:13 AM
satcom40's Avatar
satcom40
I don't know about that but here is the number for the new plug
Improved HFCM drain plug..............IH 2589259c91 cost about 15.00
Old Jul 5, 2007 | 08:14 AM
Superdudey's Avatar
Superdudey
thanks bro
Old Jul 5, 2007 | 08:54 AM
Superdudey's Avatar
Superdudey
thanks, ordered the kit from IH for for like 12$ or so, pick it up tommorow. You rock!
Old Jul 5, 2007 | 09:23 AM
npccpartsman's Avatar
npccpartsman
Pull the water drain plug first. It will keep you from getting as bad a bath from fuel as you'll get without pulling it. You need to drain it every time you change your filter anyway or perhaps more often if the water light comes on. Some people do it at every oil change.
Old Jul 5, 2007 | 10:16 AM
johnjohn2784's Avatar
johnjohn2784
yea i had the same problem...mine was sooooo tight and sort of stripped out...thankfully it wasn't totally stripped and i finally got it....now i need to ordered a new one...
Old Jul 5, 2007 | 10:30 AM
Superdudey's Avatar
Superdudey
call your local international dealer and order IH 2589259c91 . thats a good number and its cheap. Thanks to satcom40.
Old Jul 5, 2007 | 10:54 AM
06f350psd's Avatar
06f350psd
Here Check this out. It will give you the part number for ford too.
http://www.forddoctorsdts.com/articles/article-05-19.php
Old Jul 5, 2007 | 10:56 AM
Superdudey's Avatar
Superdudey
international wants 30-34 bucks, ford wants 70+. go to IH
err thats for the fuel filter. the thing you have posted is 10-12bucks from international. I avoid the ford service department if i can.
Old Jul 5, 2007 | 11:15 AM
06f350psd's Avatar
06f350psd
I wouldn't ever buy fuel filters from ford. My international dealer is 45min away so when I go I just have to stock up. I haven't priced the drain plug from ford but it is an option.
Old Jul 5, 2007 | 11:18 AM
Beerstalker's Avatar
Beerstalker
Others here have had the stripped hex problem too. I believe that most people have been able to get the plug out by putting te hex wrench in the hole and using JB weld to attach it to the plug. Let the JB weld set and then unscrew it and replace with the new IH plug. With the new plug you just tighten it by hand (and with the o-ring on there you don't have to get it all that tight). No real need to use the hex wrench anymore.
Old Jul 5, 2007 | 11:54 AM
Superdudey's Avatar
Superdudey
15.25$ they dont have it in stock but they can order it.
id still drive the 15 miles to my International dealer to save the 3 bucks only because i hate my ford dealer
Old Jul 5, 2007 | 12:01 PM
06f350psd's Avatar
06f350psd
Superdudey, sounds like you feel the same way about your ford dealer as I do. I won't deal with the ford dealer I have in town. I drive 30 minutes to another one if I have to take the truck in for something. Thanks for the price check.
MSP-F250
16
Nov 2, 2014 09:20 PM
brandon.edwards
May 31, 2013 07:19 PM
neverworry
Jul 13, 2010 09:39 PM
MPHorvat
Dec 1, 2009 05:48 PM
427ford
May 9, 2009 01:49 PM
