Now for My next problem
Old Feb 12, 2006 | 12:28 PM
jtharvey's Avatar
jtharvey
I've got a very similar noise, and I've isolated it to the leaf springs on the front passenger side. I don't have a lift, but just a front leveling kit. When the springs get dry and a little rust between them, it's my thought that they start rubbing against each other and make a knocking or popping sound. If I spray some penetrating oil on the springs, being sure to get it between the springs the best I can, the noise usually goes a way for a couple of months until the sprins dry out again. May not be your problem, but it's worth a check.
Old Feb 12, 2006 | 12:44 PM
zx250's Avatar
zx250
Of the next Riffraff East
Does the dry springs cause a knocking sound? Mine is a leveling kit with leaf springs.
Old Feb 12, 2006 | 01:34 PM
jtharvey's Avatar
jtharvey
Yeah, I'd say that's it. That's the exact same thing that I have. Try some lube on the leaf springs and see if that doesn't help. Cheap and easy to at least try.
Old Feb 12, 2006 | 02:34 PM
bloomy63's Avatar
bloomy63
check the sway bar and drop link bushings
Old Feb 12, 2006 | 03:22 PM
zx250's Avatar
zx250
I have replaced my bushings on my sway bar with polyurethane bushings at the same time I lifted the front. Could this be a problem?
Old Feb 12, 2006 | 04:19 PM
bloomy63's Avatar
bloomy63
poly bushings are good imo.
have you replaced the bushings on the drop links?, it's the bar at either end of the sway bar that attaches the sway bar to the frame?
Old Feb 12, 2006 | 04:27 PM
zx250's Avatar
zx250
Yes, I have replaced all except the ones on the axle that holds the sway bar. I can't find the right size. The ones I ordered were suppose to be right. The are a 1/4" to small dia.
Old Feb 12, 2006 | 05:11 PM
bloomy63's Avatar
bloomy63
in my experience the bushings on the sway bar against the axle will rattle and make a noise like you are describing, it depends how worn they are. I ordered my poly bushings from jegs, i think they were energy suspension and i had no problems with size. but i know that ford has used many different configurations for the sway bar on these trucks.
change those bushings and it might solve your problem
Old Feb 12, 2006 | 05:33 PM
cangim's Avatar
cangim
You could simply take the sway bar off and see if the noise goes away
Old Feb 12, 2006 | 05:39 PM
zx250's Avatar
zx250
Hadn't thought of that. I will give that a try also. Thanks
majkthreads
6.7L Power Stroke Diesel
26
Mar 30, 2015 12:46 PM
DHamSTER
17
Aug 20, 2013 08:09 PM
DSN46
Aug 2, 2013 05:52 PM
78 & 87 Super Cab
35
Jan 2, 2013 02:59 PM
snoopt1
Jul 2, 2011 01:50 AM
