Crunching Sound
Old Aug 12, 2013 | 03:01 PM
DHamSTER's Avatar
DHamSTER
Crunching Sound
Can anyone explain why when I hit my breaks or hit certain bumps I can hear a crunching sound under the truck?
Old Aug 12, 2013 | 03:30 PM
Christof13T's Avatar
Christof13T
Springs
Bushings
Ball joints
Shocks...
Check to ensure your caliper bolts are all still there.
Old Aug 12, 2013 | 03:44 PM
DHamSTER's Avatar
DHamSTER
Bushings being sway bar bushings? because I do have those and the current ones look okay. No cracks.
Old Aug 12, 2013 | 03:45 PM
DHamSTER's Avatar
DHamSTER
I just replaced the shocks and my buddy replaced his ball joints and he never had this sound.
Old Aug 12, 2013 | 04:54 PM
diehardstroker's Avatar
diehardstroker
my guess would be to check out the brakes/calipers, i heard it more on your truck when you hit the brakes.
Old Aug 12, 2013 | 05:08 PM
DHamSTER's Avatar
DHamSTER
I'm not entirely sure how to do that....
Old Aug 12, 2013 | 05:32 PM
diehardstroker
jack a side up on the front and grab the top of the tire and try to wiggle it, if theres play you have ball joint issues, pull whole tire in and out to check for wheel bearing issues, take tire off and calipers to inspect pads for any grooves, also look at the rotors for deep grooves, check slide pins while your under there
Old Aug 12, 2013 | 05:44 PM
DHamSTER's Avatar
DHamSTER
Alright. That may have to be something that we do.
Old Aug 12, 2013 | 05:47 PM
diehardstroker
you can do that! lol its pretty straight forward once you see it.
Old Aug 12, 2013 | 06:28 PM
Shake-N-Bake's Avatar
Shake-N-Bake
For me the clue here is that you hear the noise on certain bumps as well.
I am thinking spring tip isolators. They can break apart, crumble and fall out over time.
Old Aug 12, 2013 | 07:09 PM
Bonanza35's Avatar
Bonanza35
Sway bar bushing are another thing to look at. They bang pretty hard if there loose or out.
Old Aug 12, 2013 | 07:13 PM
DHamSTER's Avatar
DHamSTER
Where can I pick those isolators up at?
Old Aug 20, 2013 | 04:30 PM
DHamSTER's Avatar
DHamSTER
When I purchased my truck from a private party he gave me new sway bar bushings from NAPA and told me there was a small vibration. I have been driving this truck and as every one knows the 7.3 gives off plenty of vibration and I never noticed what he was talking about.
After a month of driving the truck I noticed a crunch when I braked or hit pumps. My first post in this thread was asking questions about it and Christof13t gave me a list to work with and I mentioned that I was given these bushings and he agreed that might solve it.
I simply sent this picture to my Buddy and he told me have it and replace those. You can notice the gap between the bushing and the bar.
I covered the bolts in liquid wrench and gave it about ten minutes to set in and then it took me about 20 more minutes to get those off and replace them and then went for a quick test drive. NO MORE CRUNCH!
Sorry about all the rust.... But then again my truck is 13 years old ;P
Old Aug 20, 2013 | 05:29 PM
Christof13T
Glad you got it sorted out.
The Gods smile on The Brotherhood.
And...
Unkle Ted for President!
Old Aug 20, 2013 | 05:39 PM
DHamSTER's Avatar
DHamSTER
Not sure what all of that means. But okay.
