Hissing sound inside cab
Old Dec 12, 2012 | 03:18 PM
78 & 87 Super Cab's Avatar
78 & 87 Super Cab
Question Hissing sound inside cab
I have been hearing a hissing sound inside the cab of My truck as I'm driving. When I shut the engine off I will still hear the sound for about 10 sec and it will stop. I raised the hood with it running, and I did not hear any vacuum leaks under the hood. What should I be checking next?
Old Dec 12, 2012 | 04:01 PM
Rogue_Wulff's Avatar
Rogue_Wulff
Power brake booster. Likely blown.
Old Dec 12, 2012 | 04:08 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
My thoughts exactly.
Either that or HVAC controls if Air Conditioning Equipped...
Old Dec 12, 2012 | 04:12 PM
Rogue_Wulff
The part about the hissing lasting ~10 seconds after shutdown, leads me to suspect booster more. However, if the truck has factory A/C, you do have a valid point.
Dealer installed A/C doesn't use vacuum, though, so I tend to forget about that aspect since mine has the dealer installed system.....
Old Dec 12, 2012 | 04:23 PM
Franklin2's Avatar
Franklin2
If you want to make sure it's the booster, disconnect it and plug the vacuum line, and then see if the hissing goes away. Don't drive it with the hose off the booster though, the brakes won't be very good.
Old Dec 12, 2012 | 05:27 PM
78 & 87 Super Cab
Crap, not the kind of news I needed. I wonder if the check valve that the booster hose goes on could be bad? The power brakes work perfectly despite the hissing.I will pull the hose and plug it to see what happens. Since I do not have the funds to replace it, I may have to live with it.
Old Dec 13, 2012 | 03:15 PM
78 & 87 Super Cab
Well, plugging the hose had no real effect on the sound,was still present, just not as loud.
Old Dec 14, 2012 | 11:41 AM
81-F-150-Explorer
Hmmm, both brake booster, and HVAC controls leaking?
Does the truck have Factory A/C? Or did it at one time?
Any aftermarket vacuum gauges installed etc?
Old Dec 14, 2012 | 01:05 PM
78 & 87 Super Cab
Never had A/C, or any aftermarket gauges
Put My ear to the firewall, definately the booster. So for now I will have to live with it till I can afford to fix it,unless someone has one they will give Me
Old Dec 14, 2012 | 03:51 PM
81-F-150-Explorer
I was just wondering why if you plugged the booster vacuum line that it would still make noise...
If it's the booster, best to get it fixed as soon as possible.
good luck.
Old Dec 14, 2012 | 04:10 PM
78 & 87 Super Cab
good luck.
I'll just have to be careful with it, as I do not have any more cash to spend right now
Old Dec 15, 2012 | 10:36 PM
78 & 87 Super Cab
Funny thing about this issue, it did not do this the first 2 times I drove it, I am wondering, if maybe the check valve is sticking somehow?
Old Dec 15, 2012 | 11:05 PM
ctubutis's Avatar
ctubutis
If you disconnect and plug the vacuum line to the booster, that removes the booster and check valve from the system, I also wonder how the booster could still be making noise if you did this?
Old Dec 15, 2012 | 11:25 PM
78 & 87 Super Cab
I have no clue, ,this problem is not really affecting the power brakes, they are working as normal
Old Dec 15, 2012 | 11:32 PM
ctubutis's Avatar
ctubutis
But I think what we're all wondering is... did you in fact disconnect and plug that vacuum line and then start the engine?
