Alternator, VIN decoding, and rearend??
Also, while I'm posting...
I have a 67 F100 and a 68 F100. I'm trying to figure out the rearend ratio's in them and what they were equipped with from the factory. I was going to use the VIN decoder in the Tech Articles section but it only goes back to 70. Can anyone tell me where I can decode my VIN and door info? Or can someone decode it for me?
The 67 is
F100ARB26289
115 M F100 481 A 09
05000 129 4000 72
The 68 is
F10YDD28486
115 6 F100 3381 F E9
O5000 172 3800 61
I'm especially interested in the rearends they have. They are very different. I believe the 67 has the Ford 9in rear with 3.70 ratio, from the look and the id plate numbers i took down
(WDM-K 3.70 7DB 302). But the rearend in the 68 has a completely different look. It doesn't have bolts on the front, shaped different and on the back there is a big drain plug with a big square/cube to turn it with. Is this a Dana rearend? If so how can I figure out the ratio it has?
Sorry to ramble on so long, like I said i've done alot this weekend and I'm dying to figure this stuff out. I may not know much but I have a passion for it. Thanks for any help guys.
hope this helps
John
jowilker
[link:www.ford-trucks.net/users/jowilker|Club FTE since 01 01] My FTE Page
[link:www.ford-trucks.net/users/jowilker/NCFTE.html|NC Truck Owners] NC Ford Truck owners group
66F100s Rule
In the cool still quite of night you can hear chevies rusting away.
The trick is getting the brushes back into their holders and keeping them there while you reassemble the alternator. If you get a piece of stiff wire about six inches long you can use it to retain the brushes. There is a cutout in the brush holder to allow this wire to go thru and out the back of the alternator. After you reassemble the alternator pull the wire out and the brushes are bak where they belong.
Also very important scribe a mark across the halves of the alternator so that you put it back together with the halves lined up as they were before.
By the sounds of it you need a new stud intalled, any correct sized bolt will work. Put the bolt thru and tighten a nut and lockwasher onto it, make sure that the insulator is still in place. Then when you connect the wire just use another nut, that way you wont have to hold the bolt inside the alternator.
Have fun.
Sparky
Thanks for the info on the alt. Still sounds complicated since I've never done it before, might try it, might not. As for now my problem is solved. Between me and my Dad we figured we'd bought an alt. from Autozone that had a lifetime warranty or something like that. So I took it in pretending it was the one under warranty and they replaced it no trouble. (happy day) But i went to take the alt. off my 68 and it did the same thing on me, so I may still need to take one apart.
And for whoever said put a GM alt. on here? Not to start a war of words, but I'd pull the truck with a rope tied to my genitals before I put any GM part on there. Death First!!
Thanks for the help guys, it's really appreciated. Does anyone happen to have an answer the my rearend id problem? I've been searching the archives but so far nothing.
With the rear wheels jacked up. Make a chaulk mark on the floor and a corresponing mark on the tire . Now,crawl under and turn the driveshaft either direction and count the number of turns of the driveshaft that it takes to rotate the wheel one revolution or (Back to the chaulk mark on the floor).
The number of turns equals the gear ratio of the rear end.
3 1/2 turns = 3.50:1 >
2 3/4 turns= 2.75:1 or 2.79:1 and so on.
Hope this helps.
About this rear end. Are there any codes available at all?
A tag ?
Dennis
As for the jacking up and turning the driveline and all, it's a little hard for me. My trucks are out in the country and it's all sand and dirt, no shop. So I am crawling in sand all day to do that stuff. And it leaves me without a level surface much of anywhere. Oh well, I'll get them to pavement and find out for sure here one day.
Thanks for all replies and any other information anyone can render. This place rocks!
>To get the ratio on the
>rearend.
>mark on the tire .
>end.
>and so on.
>Hope this helps.
>A tag ?
>Dennis
