speed density vs. MAF
Old Feb 8, 2006 | 10:27 PM
spidk43's Avatar
spidk43
ahahhhhhhh.... good point. Is there anything (other than a tranny swap) that could be done to make things work out for the better? (e4od, 351W)
Old Feb 8, 2006 | 10:37 PM
Blurry94's Avatar
Blurry94
About a year ago, when I was truck shopping, I looked at two mid 90's F-150's with 300's and both were equiped with factory mass air systems with auto transmissions. My guess is if you can find one of these at a bone yard, your swap wouldn't be all that difficult.
Old Feb 9, 2006 | 08:38 AM
whiteyfordzx5's Avatar
whiteyfordzx5
anyone know how CA laws like this kind of swap? is it CARB-legal?
Mike
Old Feb 9, 2006 | 01:59 PM
kjg26's Avatar
kjg26
sorry to hijack. i'm very close to doing a rebuild/replacment of my current 351. if i go the replace route i'll be putting in a new 351. at this point could i just use a newer 351, one with a MAF? would i have to change computers?
thanks
keith
Old Feb 9, 2006 | 08:46 PM
Blurry94's Avatar
Blurry94
thanks
keith
The motor itself doesn't constitute a mass air swap. However, if you plan to install a mass air wiring harness and air meter, then yes, you will need a mass air PCM.
Old Feb 10, 2006 | 01:11 PM
kjg26's Avatar
kjg26
ok thats what i needed to know. Thanks
Keith
Old Feb 10, 2006 | 08:51 PM
Chevy_impala57's Avatar
Chevy_impala57
better gas millage!!!!!!!!!!!!!! and if you want auto you can swap in a aod, c6, (c4 it think) You have to look around but theres places where you can buy a e40d Controler which is completly seperate from the ecm, some you can even plug a lap top into it and chose when you want the trany to shift but it will coasts a couple of bucks. And if your realy up to the challange you can wire the truck computer up to run transmission controls , and the mustang computer to run engine controls
Old Feb 10, 2006 | 08:57 PM
Popa Tim's Avatar
Popa Tim
some 94 F150's came factory with E4OD and Mass Air.
While scouting the junkyard don't overlook the trucks
Old Feb 10, 2006 | 09:30 PM
frederic's Avatar
frederic
yes, some 94s. Most 95's, and all 96's. Mass air, 351W, and E40d. Finding those parts is probably the easiest way to make the swap work.
The EEC's are still available from places like rock-auto.com.
Mass Air Sensor: F5UZ-12B579-BA
Baro/Map Sensor: E7EF-9F479A1A
EEC Module: F6UF-xxxxx-NA/NB
EEC Module: F6TF-xxxxx-AEC (CA, NY, MA)
Remote TFI: EZ12A297A
All the other sensors are generic enough you can yank them off 90-97 thunderbirds, town cars, crown vics, marquis, F-trucks/E-vans, and so forth.
If you can't find the correct wiring harness out of a 96... they are easy enough to make using several wiring harnesses that you splice together. I just finished making one for my crewcab... took a few weekends with interruptions.
J23wlsc
Oct 11, 2007 09:07 PM
JAYNESStheGreat
1978 - 1996 Big Bronco
May 26, 2003 12:25 AM
LxMan1
Dec 24, 2002 07:19 PM
PAUL_2
Mar 28, 2002 08:17 PM
