Speedometer Cable
Old Jun 14, 2001 | 08:44 AM
AaronW's Avatar
AaronW
Speedometer Cable
Is there supposed to be a fitted end to the speedo cable. I disconnected mine when I took out the dash and noticed that the end is just wire. Now the speedo whips back and forth until about 25 when it smooths out. It may need some lube, but I thought there was supposed to be an end to the wire. Am I right?
Thanks
Aaron
Old Jun 14, 2001 | 10:33 AM
StockMan's Avatar
StockMan
Speedometer Cable
[FONT COLOR="#0000ff" SIZE="3" FACE="Veranda"]
The end of the original would just be wire, but it would be squared off. The replacement cables often have a crimp on end. It sounds like you are either missing the end, or perhaps your cable does need lube. Use lube intended for speedo cables otherwise you may run into problems.
[/FONT]
[LINK:www.hometown.aol.com/tbeeee|http://members.aol.com/tbeeee/page/registrysig.gif]
Old Jun 14, 2001 | 10:43 AM
BB's Avatar
BB
Speedometer Cable
Hey StockMan, good to see 'ya around again!
Barry
Old Jun 14, 2001 | 11:32 AM
AaronW's Avatar
AaronW
Speedometer Cable
It is squared off, so I assume its original. Is it hard to find speedo lube?
Old Jun 14, 2001 | 03:01 PM
StockMan's Avatar
StockMan
Speedometer Cable
Aaron: Try your local NAPA.
Barry: It's amazing what you can accomplish while in lurking mode. :-)
[/FONT]
Old Jun 15, 2001 | 08:23 AM
Groundhawg29's Avatar
Groundhawg29
Speedometer Cable
53rat
Jul 27, 2012 05:10 PM
Yaga1973
Apr 19, 2012 09:30 PM
acurtiss
Jul 4, 2007 08:47 AM
Wakeboarder141
1978 - 1996 Big Bronco
15
Aug 4, 2004 09:48 AM
chickenmanq
May 17, 2002 07:58 PM
