1978 - 1996 Big Bronco
axle codes.....
Old Feb 15, 2006 | 07:13 PM
BroncoRoadKill's Avatar
BroncoRoadKill
Thanks all who replied. So since I have 3.00:1 ratio, then somebody has been into the c6, cause that thing takes off like it has 3.55:1 gears
Old Feb 16, 2006 | 02:36 AM
justshootme84's Avatar
justshootme84
Yeah, that makes more sense to me now. Turn one wheel 2X to get the carrier to make one revolution and three revs of the driveshaft to equal a 3:1 ratio. You must have had the tranny in park instead of neutral, which is why I suggested turning the driveshaft instead of a tire/wheel. Anyhow, even a standard C-6 that's been recently rebuilt will slip very little compared to the old one with alot of miles and worn clutches, plus you have a fresh engine. Many times, the "sluggish" feeling you get from the use of taller-than-stock tires is due to a poorly running engine or tranny problem. If you ever get a chance to ride or drive a similar-equipped Bronco with 4.10:1 gears and 33" tires, you may re-think the performance of your 3.00:1 ratio. You'll be glued to the seat upon take-off!!!
Old Feb 16, 2006 | 06:34 PM
BroncoRoadKill
Well, it doesent slip much at all when its warmed up. Ever heard of anyone reprograming a valve body to run a c6 in low range?
Old Feb 16, 2006 | 06:44 PM
BroncoRoadKill
Justshootme Look to the bottom of this thread and the next page. I started a thread in the tranny diff forum.
https://www.ford-trucks.com/forums/s...2&page=2&pp=12
Russ74
Mar 30, 2017 10:35 AM
retro48/52
Mar 28, 2014 09:51 PM
dustman
Nov 27, 2011 07:37 PM
byro01
Dec 3, 2007 12:01 PM
Redneck Trucker
Jan 4, 2005 05:50 PM
