Rear axle code help
Old Mar 28, 2017 | 03:46 PM
Russ74's Avatar
Russ74
Rear axle code help
Apparently I'm one of the few lucky ones who bought a truck with the ID tag still on the axle. I found a site that tells me most of the info. But I can't tell if this is an open or Trac-Lok differential. Code reads as follows.
WDM-AG1 4FA
3.00 9 344A
This is on a 74 F100 2WD. Any help is appreciated.
Old Mar 28, 2017 | 04:05 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Code reads as follows: WDM-AG1 / 4FA / 3.00 / 9
WDM-AG1 = Ford 9" Rear Axle / 3.00-1 / No Limited Slip / 31 spline axle shafts.
4FA = Assembled the first week (A) of June (F), 1974 (4).
Old Mar 28, 2017 | 04:33 PM
Russ74's Avatar
Russ74
So my suspicions were correct. I've got a peg leg. Thanks for the help!
Old Mar 29, 2017 | 04:57 PM
D-rat's Avatar
D-rat
Another quick and dirty way to tell is to jack up under the diff, put in neutral, and spin a tire. If the opposite side spins in an opposite direction, it's open; if it spins the same direction it's locked or has a functioning limited slip.
Old Mar 30, 2017 | 10:35 AM
Russ74's Avatar
Russ74
I was preparing to do just that when I noticed the tag buried under years of dirt.
BLDTruth
Apr 22, 2016 08:29 AM
Baja16
17
May 16, 2013 11:59 PM
nothercrash
May 25, 2011 10:29 AM
samickguy15
Jan 12, 2007 08:15 PM
pditmars
Jan 19, 2005 11:42 AM
