vin decode? and other stuff
Old May 10, 2013 | 02:51 PM
  #61
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by GuszFalcon
i finally started on my project, a 1965 Ford falcon Econoline (clubwagon ?) with a swapped V8 in the dog house. I am Europe based so not near to any references.
Started the engine, runs on petrol as well as LPG. Brakes where stuck but I remove both front brake disks (drums) and am now looking to buy a drum to disk kit.
I am looking for the vin number but so far I found these numbers on the edge of the doghouse. VIN: E13TH649687
The exhaust manifold has the number CG OE-9430-F
2nd digit of prefix is a number, could be a 6.
The valve covers have 5 bolts. What engine do you think I have? Is it a 302?
Welcome to FTE
1969: First year Econolines were available with a V8 (302).
It cannot be a 302 as only FE engines (352/360/390 and etc) have 5 valve cover bolts per side.
6 valve cover bolts per side: 221/260/289/302/351W
While FoMoCo installed Falcon nameplates on some of these vans, they're really Econolines.
E13 = E100 (Econoline) Deluxe Club Wagon.
T = 170 1V I-6.
H = Lorain Ohio Assembly Plant.
649687 = 1965, assembled February 1965.
Old May 10, 2013 | 03:15 PM
  #62
GuszFalcon's Avatar
GuszFalcon
Hi NumberDummy
tnx for the quick reply
the engine intake manifold says fring order 15426378
Also FoMoCo and digids 68ZE
the second digid on the manifold should/could be a 6
what does this tell me? i am sure it is a V8 :-)
Checked the images and the valve cover has 6 bolts, so is it a 302?
cheers
Old May 10, 2013 | 05:50 PM
  #63
NumberDummy
The engine intake manifold says firing order is 15426378. Also FoMoCo and digits C8ZE
The second digit on the manifold should/could be a 6, what does this tell me? i am sure it is a V8.
Too many engines have this firing order to pin it down. 6 valve covers bolts will be found on all 1962/63 221's, 1962/65 260's, 1963/68 289's, 1968/96 302's, 1969/97 351W's.
C6OE exhaust manifold casting number prefix applies to 1966, but could also apply to 1967 and thru the 1970's.
C8ZE intake manifold casting number prefix applies to 1968, but could also apply to 1969 and etc.
People love to swap parts, so attempting to pin down the actual year of the engine won't be any more successful than Operation Market-Garden was. A fiasco...where Monty met his personal Waterloo...at Arnhem.
Is it a 302? Maybe yes, maybe no. Measure the stroke to determine engine size: 289 = 2.87" / 302 = 3.00" / 351W = 3.50."
Fordman96
May 24, 2016 09:25 PM
Stonesetter1
Jan 14, 2015 09:06 PM
John Clugston
18
Feb 17, 2013 03:23 PM
Nincompoop
1997 - 2003 F150
Dec 22, 2011 10:20 AM
ntowns9978
2004 - 2008 F150
Feb 22, 2011 08:52 AM
