Key/Light Ding Ding ...Ding Ding
Old May 4, 2006 | 08:08 PM
  #31
Lushman's Avatar
Lushman
Originally Posted by robbies_f350
I have an 04 and 01 powerstroke, disconnected the wire under the seat and no problems with the air bags.
Did you try them somehow?
Old Mar 20, 2007 | 02:12 PM
  #32
st3ib's Avatar
st3ib
didn't have to take the column apart at all
I went to disable the key reminder today and was about to take the column apart when hey, i think that is that black and pink wire. there is a group of wires that run down from the column and into a connector. i took the connector apart and took the retainer clip off it then did a little pry on the snap clip, and out it came. now when i .......i mean if i ever sell, it will go back together 1,2,3
Old Dec 6, 2007 | 10:28 PM
  #33
jbkgmyers's Avatar
jbkgmyers
Door chime even w/ key out & Int./Ext. Lights stay on
Hello,
I'm new to this forum, 1st post..... Just wanted to say thanks to you all. I have an 03 Expy, 6.8L and the door chime has been driving me insane for the past 4-6 months. Even with the key OUT of the ignition, the fricken chime would ding with the oor open. Talk about going crazy!?!?!?! Also, every once in while the interior lights wouldn't go off after the family would get in the truck, or exit the truck. The lights (interior & running boards) would stay on for sometimes 30 minutes.
Thanks to this forum I fixed both problems in one night. Removed the ignition assembly from the column, found the "chime" switch and basically disconnected it. Then I followed the WD40 trick on the latches of the doors (incl. rear) the clean the switch contacts there too... Everything works great, I finally like my truck again!!!!! (And my wife likes me again!!)
Again, thanks for all your help!
Jeff
Old Dec 6, 2007 | 10:33 PM
  #34
DaveWilliams's Avatar
DaveWilliams
Welcom to FTE
Welcome to the family and we hope you find all the information you are looking for, and if you have trouble, just ask...Merry Christmas, Dave
Old Dec 7, 2007 | 10:25 AM
  #35
badger2196's Avatar
badger2196
Originally Posted by Kwikkordead
You could cut it and then later on rejoin it with a butt connector.
That's exactly what I did - cut the wire and put bullet connectors on the cut ends. Reconnecting them is a snap if needed.
TAZ DEVIL
Aug 19, 2020 01:03 PM
wharthog
Oct 20, 2017 08:55 PM
brabey
1997 - 2003 F150
Oct 9, 2015 04:46 PM
shok47
1983 - 2012 Ranger & B-Series
Nov 10, 2012 09:36 AM
t_mckenzie
May 6, 2003 11:33 PM
