I bought a 77 F150 with a 400M/c6. It runs alright, but if I give it more than about half throttle it bogs bad. It has a 2bl carb. I know nothing when it comes to carburetors. Does it need to be adjusted, or do I have another problem somewhere else?
68 F-100 Short bed 2wd
302 C4 9" w/3.50 gears
Soon to be sportin' power discs and steering
I had the same problem, I took the carb apart , soaked it for a day in solvent, the put a kit ($20) in it. it worked, I could smoke the tires down with 2.75 gears:}
