Hello,
My truck is vapor locking after it reaches a certain temp, I think. After a "cold" start it runs great for approx. 10-15 min, but then it stalls and it will not start until it sits for a while and cools down.
I rebuilt the carb and replaced the fuel line from the fuel pump to the carb. I also installed a new fuel pump with insulation to the line so that my fuel will not boil from engine block. All this I did before this new challange.
The problem started shortly after I mud bogged for a couple of hours and drove over a dip on the trail. came down hard and it stalled. When I went to crank it on again, it hassitated a tad but it started. Then a minute later it stalled and would not start. But did turned over as it presently does.
Can anyone give me a tip in what might of happened that's causing this stalling raw deal and how I might be able to fix it.
Next time it vapor locks and dies, (with the key off) take off the air cleaner and move the throttle - notice if gas squirts down the throat of the carb. If it truly is vapor locked, there will be no gas squirts. If there is gas in the carb, check for spark.
Knowing whether it's a spark problem or fuel problem is the first step.
After the checking float level, go over every inch of fuel line. Is the rubber hose on the steel line to the tank new? Steel line smashed anywhere?
Go over your evap fuel system: The canister, vent in the tank, all the hoses. Maybe a vacuume leak in the cannister purge (thermal vac switch?) or maybe the tank is not venting. If you decide to drop the tank, check the fuel pick up tube for rust or holes. I had one of those fall apart in my hands-nasty. Hopefully you won't get that far. LOL
I've yet to investigate everything that was requested.
I was looking at my truck last night. I let it run/idle while in park for 20 some minutes and when it reached a high temp in the engine I noticed a small air leak from the manifold's gasket. The reason I feel it was a leak was because I noticed some build up bubling up from the right side of engine block and where the manifold joints. So I was wondering if that could be effecting the spark wires from that side where heat is blowing out from the leak.
I also checked for temperature on the opposite side of engine and it appeared cooler.
So, do you guys think that my spark plug wires may be getting over heated by the broken gasket and causing it to stall?
FYI. The truck iventualy stopped on its own as before.
Thanx again!
Mud
Marty
Yes, fuel is being pumed from the throat of the carb. Am I supposed to get some fuel out from the 2 upper shoots/ports by the top of the carb's choke flap plate as well? Because nothing come out of them. And yes I did this with key off.
A small miss-up on my gasket leak though (on reply #5). I meant to say Header gasket leak and not manifold.
Thanx guys!
Mud
No, The fuel should spray directly into those 2 circle things (called venturi's) down inside the carb.
This has peaked my interest: what is happening that you are considering it....vapour lock ?
it reaches a certain temperature on a cold start. It will run for approx. 15-20 min. then simply dies. Then when I try to start it up again, it crancks over but won't start until it cools it self down again.
yep. fuel is being sprayed right above them 2 barrel thingies. I'm going to replace the header gasket tonight. That leak seems like it's generating alot of heat on 2 spark plug wires.
Mud
Man, heat on that wire will only make a misfire at most! Do a full tuneup, plugs, wire, cap, rotor, ect. Have you considered it may be an idle issue? They're supposed to do a fast idle for warm up then slow down for normal idle, have you tried adjusting your idle?
This is what I did before this problem arrived (mechanicaly);
I gave it a full tune-up by replacing.
new cap and rotor
new plugs
new wires
new distributor
overhauled the carburator
new fuel filter at carburator
new short fuel hose (approx. 1" long) that connects to the carbs fuel filter.
new fuel line (metal) and fully insulated.
new mechanical fuel pump.
and timed the engine because of new distributor.
All of that I did and the truck ran great. Until I gave it a hard run mud bogging and by mistake took flight in the trail and landed hard and stalled. Thats when the challange arrived. I rechecked everything that I worked on and nothing seemed out of whack. Except that I noticed the header gasket leak this time. Eitherway I'm gonna have to replace that gasket.
