Blinking check engine light
Old Jan 29, 2006 | 01:53 PM
jco's Avatar
jco
Have a 1999 Ranger and the checkengine light came on and the truck was idling really rough. After reading many forums with the same symptoms, I changed out the PCV valve, EGR valve and the EGR valve sensor. Seems to run a bit smoother but now the check engine light is blinking?
Old Jan 29, 2006 | 03:25 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords.
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Jan 29, 2006 | 04:30 PM
jecsd1's Avatar
jecsd1
Am I wrong or does a blinking CEL mean a misfire? check DTC's. If it happened all of a sudden you've likely lost a plug, wire, or a coil pack. Mine did the same and it was the coil pack.
Old Jan 29, 2006 | 06:21 PM
jco's Avatar
jco
checked the spark plug wires and on one of them te rubber is cracked around where it connects to the spark plug. could this cause the problem?
Old Jan 29, 2006 | 08:26 PM
AlfredB1979's Avatar
AlfredB1979
You might be on to something, but unless you take the time to check for engine error codes, we really can't do anything but nod at your guesses.
Sorry.
You may have tossed money at stuff you didn't need as well.
Old Jan 29, 2006 | 09:33 PM
Rockledge's Avatar
Rockledge
Welcome.
A flashing CEL means the engine is misfiring bad enough to cause possible damage to the catalytic convertor(s).
Places like Autozone will pull codes for free. Get the codes pulled, write them down and then let us know what they are.
lianora
May 22, 2014 09:50 PM
johnblade
Jan 2, 2014 09:04 PM
rfmodulator
Dec 28, 2013 09:23 PM
jackf62
2004 - 2008 F150
Sep 22, 2009 10:11 AM
timbo65
22
Aug 18, 2007 01:15 PM
