Cleaning an engine.
Old Apr 5, 2006 | 12:49 PM
  #31
dolcevita09's Avatar
dolcevita09
Originally Posted by 79f-250custom
IDM =Injector Drive Module. dont ask me what it is or what it does because i have no clue. hahah, but some 1 else will chip in i think.
Mitch
Thank you. Do you know where it is located and what it looks like by chance?
Old Apr 5, 2006 | 02:56 PM
  #32
79f-250custom's Avatar
79f-250custom
No i dont. ill try looking around on the net and getting a pic of it and posting it up here.
Mitch
Old Apr 5, 2006 | 05:56 PM
  #33
Briansshop's Avatar
Briansshop
Idm
The IDM is in the upper driver's side of the engine bay, to the right & forward of the brake booster. It's an alum box mounted on it's side.The IDM fires the injectors when the PCM tells it to.
Brian
Old Apr 6, 2006 | 03:29 AM
  #34
soutthpaw's Avatar
soutthpaw
Hey read your owners manual and it will tell you never to spray water onto a hot diesel engine!
Old Apr 6, 2006 | 08:47 AM
  #35
F350_Hauler's Avatar
F350_Hauler
I don't think anybody said hot. I believe they all mentioned warm.
Old Apr 6, 2006 | 10:52 PM
  #36
soutthpaw's Avatar
soutthpaw
OK whatever, go ahead and crack your head or block or manifold as you cant tell exactly how "warm" or hot every engine part is. But i have a steam pressure washer so i dont have to worry, I can clean it cold.
Old Apr 8, 2006 | 12:25 AM
  #37
79f-250custom
you can you know maybe put your hand on the engine and see how hat the block or manifolds are and then spray away.
any body have any luck with oven cleaner here. i bought some and used it and couldnt tell the difference.
Mitch
Old Apr 8, 2006 | 05:33 AM
  #38
F350_Hauler
Does that thing work good? I am thinking about renting one for a weekend and doing everything at once.
dan b
General Diesel Discussion
13
Mar 15, 2010 10:29 PM
Jason6969
Jan 19, 2009 04:17 PM
caseydudem
22
Jul 31, 2007 12:23 PM
cbfomoco
Oct 22, 2005 07:59 PM
Stomper4x4
1978 - 1996 Big Bronco
16
Sep 24, 2003 12:49 PM
