390 swap :)
Old Aug 8, 2001 | 03:02 PM
Irondale90's Avatar
Irondale90
390 swap :)
[font size="1" color="#FF0000"]LAST EDITED ON 08-Aug-01 AT 04:47 PM (EST)[/font][p]I have a FE 390 to swap into my 77 F-150 4x4 C-6 tranny. I have the 390 and a 2wd C-6 to bolt it to. Someone told me that all I have to do is change out the back part of the 2wd tranny with the back part off the 4wd and the whole thing will bolt right in with the engine mounts, length and everything. Is this true...any sugestions?
thanx
I have a 351M/400 in it right now
Old Aug 8, 2001 | 03:19 PM
sparky's Avatar
sparky
390 swap :)
I have a FE 390 to swap into my 77 F-150 4x4 C-6 tranny. I have the 390 and a 2wd C-6 to bolt it to. Someone told me that all I have to do is change out the back part of the 2wd tranny with the back part off the 4wd and the whole thing will bolt right in with the engine mounts, length and everything. Is this true..,.any sugestions?
thanx
All depends on what was in the truck before, being a 77 I don't believe they came with the FE series of engines. So motor mounts, rad, accessories, tranny mount, crossmember, exhaust, to name a few will have to be changed/relocated.
Someone correct me if I made any mistakes
Sparky
Old Aug 8, 2001 | 03:38 PM
Irondale90's Avatar
Irondale90
390 swap :)
oh yes...I have a 351M in the truck...the 390 was available in the 76 and before. The 351M/400 replaced the 390 in 1977
Old Aug 8, 2001 | 06:38 PM
Like M. Fords's Avatar
Like M. Fords
390 swap :)
The output shaft will have to be swapped also. On the 4wd output shaft there is usually a snap ring that keeps it in. To get the snap ring off, you must pull most of the C6 guts out. The 2wd version that has the ball bearing on the output shaft is held in by the bearing and extension housing, so it is a breeze to pull--it can come out with the extension housing.
Old Aug 9, 2001 | 07:38 AM
dzjammer's Avatar
dzjammer
390 swap :)
The output shaft is shorter on a 4x4 C6, otherwise they're the same. You might be better off getting a 4x4 C6 and trading it out.
Dave,
79 F-150 4x4, 390 w/C6, Edelbrock carb, 33X12.50 never will be finished.
Old Aug 9, 2001 | 08:30 AM
ksd's Avatar
ksd
390 swap :)
uniboy95
Mar 17, 2014 09:37 PM
stromburg
Oct 11, 2012 09:43 AM
littlefuzz
Apr 25, 2009 02:18 AM
funkdogge
Sep 22, 2005 08:12 AM
Bulldog187th
Nov 11, 2003 06:38 PM
