C6 tailshaft swap
Old Apr 24, 2009 | 01:02 PM
littlefuzz's Avatar
littlefuzz
C6 tailshaft swap
I need yall's help again I have two C6 trannys. One is out of a truck with a 460 and 4x4, the other is out of a 2WD with a 390. I need the tailshaft from the 460 tranny in the 390 tranny. I took the tail housing off and that's about as far as I could go. I tried to take the front cover of the tranny off and I couldn't get it out after taking all of the bolts out. I'm stuck
Another question: Is it easier to pull and install the engine, tranny, and transfer case all togather? I had a hell of a time getting the tranny and transfer case out by themselves because I couldn't get the crossmember out.
Old Apr 24, 2009 | 02:11 PM
littlefuzz's Avatar
littlefuzz
Another question while I'm at it, I'm assuming the torque converters would be the same, right? Wrong? Sorry for all the questions, I'm a welder but not much of a mechanic
Old Apr 24, 2009 | 03:30 PM
rclarke's Avatar
rclarke
The output shaft in a C6 is the last thing out of the case. Same as an overhaul. The 390 torque converter is different from a 460 torque converter.
Old Apr 25, 2009 | 02:18 AM
littlefuzz's Avatar
littlefuzz
Thanks, I did find a nice pictiorial of a C6 rebuild in case anyone else is interested Removal, Rebuilding, and Installation of a Ford C6 Transmission - Pictorial Reference - Fourdoorbronco forums
I'm kinda nervous and excited at the same time about tearing into it
svemike
53
Oct 19, 2016 12:42 PM
dipstick429
Jan 23, 2015 09:04 PM
Buck268
2009 - 2014 F150
Jan 2, 2015 05:58 PM
Tyler S
Oct 18, 2014 11:08 PM
CountryBumkin
Aug 22, 2014 12:42 PM
