Sponsored by: Real Truck
2006 leveling lift
Old Jan 20, 2006 | 12:16 PM
bansheemike's Avatar
bansheemike
2006 leveling lift
Just bought the Rancho 2.5" lift springs for my 06 sd diesel. Will I need to relocate the track bar with a track bar kit?
Old Jan 20, 2006 | 03:52 PM
stebab's Avatar
stebab
Yes, I think so.
Old Jan 20, 2006 | 10:34 PM
bansheemike
I talked to a guy at 4wheel parts wholesalers today and he says no. HELP!!!
Old Jan 20, 2006 | 10:35 PM
cc322's Avatar
cc322
I would I did it with mine on the Donahoe kit, just curious why you chose Rancho over the Donahoe?
Old Jan 20, 2006 | 10:39 PM
bansheemike
I used Rancho before on my Jeep and they have free shipping right now. I thought I was buying the spacer kit but it turned out to be new springs for $144.
Old Jan 20, 2006 | 10:56 PM
BFR250SD's Avatar
BFR250SD
Take a look a the angle of your track bar and the drag link coming off your pitman arm. Those two should be parallel. If not, you want to get a bracket other wise it will cause a slight binding through the suspension cycle.
It won't be anything major and maybe not even anything you'll notice. The other reason is, the more angle that the those two components have, the more it increases your turning radius and also gives more side to side movement of your axle.
Old Jan 20, 2006 | 11:57 PM
bansheemike
Thanks. I plan on installing the kit tomorrow if the weather cooperates.
Old Jan 21, 2006 | 08:43 PM
bandaman's Avatar
bandaman
I don't think it is absolutely necessary, but a good idea. I put 2" coil spacers on my 06 with snow plow prep springs (basically a 3.5" lift) and everything worked fine, but the axle is shifted slightly to the driver's side, maybe 1/2" to 1".
Old Jan 22, 2006 | 05:58 PM
RickKimbrell's Avatar
RickKimbrell
Did you truck come out level? I have an F350 4x4 and do not have the snow plow springs. I think my truck still sits low in the front end. Was considering replacing the springs with the longer springs to see if it will come up level. Just curious.
Old Jan 22, 2006 | 07:25 PM
bansheemike
Didn't lift it yet. I"m shooting for Friday. Thinking about what bandaman said and I'm going to stop by 4wheel parts this week and check out the track bar kit.
Old Jan 24, 2006 | 10:21 PM
bandaman's Avatar
bandaman
yep, I think it looks pretty good. I think it ended up about 3/4"-1" high in the rear (measured to top of wheelwell) looks good and still is not nose high with a quad in the back or a light trailer on the hitch, check my gallery for pics. i'll try to add a better side profile when I can get to it.
AllAboutDaZ
Mar 12, 2014 02:01 AM
Heavy97Duty
25
Apr 28, 2012 01:27 PM
viperbluelx
Dec 19, 2007 09:57 PM
edub32
Dec 14, 2007 08:09 PM
Ford79
Sep 4, 2002 03:10 PM
