hard starting cold
Old Jan 19, 2006 | 03:53 PM
ret72's Avatar
ret72
hard starting cold
88 150 302 sets all night and have to really grind on it. This came on kind of quickly. What to look for first. runs good after it gets going
REt72
Old Jan 19, 2006 | 03:56 PM
whiteyfordzx5's Avatar
whiteyfordzx5
have the battery tested. sounds like its not holding a charge too well. most auto parts stores do it for free. a quick test is only a couple of minutes, and a full load-hold test requires about an hour or so.
Mike
Old Jan 19, 2006 | 05:13 PM
quicklook2's Avatar
quicklook2
bad wires or cap or plugs.
does it crank slow?
Old Jan 19, 2006 | 06:11 PM
andym's Avatar
andym
I would vote battery as well. Although a tune-up is never a bad idea if one hasn't been done in a while.
Old Jan 19, 2006 | 06:57 PM
ret72's Avatar
ret72
ret72
heck no guys, spins like a top. and as it is not flooded when it starts, I think it is not getting fuel when cold. What sensor controls that operation?
REt72
Old Jan 20, 2006 | 07:59 AM
stevcher's Avatar
stevcher
hard starting when cold
Would look at iac sensor on throttle body may be sticking.Remove and spray
with throttle body cleaner their is a small needle valve in their that you can see
thats gets carbon build up and will stick.Also try some dry gas you may have
some mositure in fuel line.Also if you havnt change fuel filter in awhile may be a
good idea to replace.
Old Jan 20, 2006 | 01:51 PM
spike552's Avatar
spike552
I have an 87 f150 and i had the exact problem you speak of and the only thing we replaced was the starter, starts every turn, and i live in CT some cold weather to start a truck on one try. Give it a shot let us know.
Old Jan 20, 2006 | 02:06 PM
quicklook2's Avatar
quicklook2
he says it spins good just does not start.
that does not sound like starter or battery.
Old Jan 20, 2006 | 02:12 PM
spike552's Avatar
spike552
He says grinds and from my knoweldge when the starter does not catch it does what it grinds.
Old Jan 20, 2006 | 02:15 PM
quicklook2's Avatar
quicklook2
spike, he is not very clear on what is wrong.
Old Jan 20, 2006 | 02:19 PM
spike552's Avatar
spike552
Yea ill drink to that
ret72
29
Aug 30, 2010 09:14 PM
USN-Ret.
Aug 5, 2010 10:29 AM
ret72
Jul 16, 2006 07:02 AM
ret72
Aug 1, 2003 10:45 PM
