Check Engine Light E150
Old Jan 17, 2006 | 05:39 AM
CM1's Avatar
CM1
I have a 88 E150 conversion van that the check engine light comes on when the engine is under a load but when I let off the gas the light goes out. My old code reader doesn't show anything wrong.
any help would be appreciated
Old Jan 17, 2006 | 05:47 AM
Beast12's Avatar
Beast12
Hi and welcome to FTE! Be sure to read this to help you around this site: https://www.ford-trucks.com/forums/s...88#post3272088 There are also State, Provincial and International Chapters located near the bottom of the main forum page.
We are glad to have you. Hope you enjoy the site. Check out the various forums. Lots of great info for you.
Thread moved to Full Size Vans forum.
See ya on the boards!
-Matt
Old Jan 17, 2006 | 02:49 PM
subford's Avatar
subford
I have a question for you, where is the check engine light on the 88 E150?
Do you have a 5.8L engine?
Old Jan 17, 2006 | 10:00 PM
CM1's Avatar
CM1
The check engine light is located on the drivers side, at the bottom left of the dash by the parking brake release.
The engine is a six cylinder 300cid
Old Jan 19, 2006 | 06:17 PM
E-150's Avatar
E-150
If you look at my gallery I have a pic of where the check engine light is located.
Old Jan 19, 2006 | 08:45 PM
coolmom3213's Avatar
coolmom3213
try to spray out the air control valve,with a cleaner from autozone,this may help it from the light comming on and off.also check your vacuum hoses in the van on the map sensor and the vacuum canister near the battery this could cause it the light to come on and off.hope this has helped!
Old Jan 22, 2006 | 11:08 PM
Heavy460's Avatar
Heavy460
i use to get the same thing.A tune-up fixed it.
Old Jan 27, 2006 | 01:59 AM
CM1's Avatar
CM1
Thanks for your input
I took the van to autozone and had it checked, the oxygen sensor was bad, I replaced it and now everything works properly
rbeesley
Oct 29, 2015 03:56 PM
racecar13
Dec 10, 2014 02:14 PM
chris_e150
Mar 8, 2013 12:46 PM
Smokey6111
Dec 6, 2011 03:14 PM
mikevv
May 10, 2009 01:01 PM
