e-150 Check Engine Light
Old Dec 2, 2011 | 01:29 PM
Smokey6111's Avatar
Smokey6111
I have a 94 E-150 5.8l. The check engine light is on and the engine is in a high idle. Does any one know what could be causing this? Any advice would be appreciated. The light use to come on, but always go off. Now it is just on.
Thank you!!!
Old Dec 2, 2011 | 08:10 PM
pl77's Avatar
pl77
It could be anything. If you don't want to pay the dealer to check the codes, why don't you pick up an OBD II code reader from an auto parts store for $70-100 and read the codes yourself? Once you've got the codes, put them here and people can give you much more precise feedback.
Really, it's the best approach. One trip to the dealer to check codes is going to cost you more than that. If you don't read the codes, you're just going to waste money throwing parts into it until you trip over the actual issue, if you even find it at all.
EDIT: Here, it's $53 on Amazon with free shipping:
http://www.amazon.com/Equus-3030-Inn.../dp/B000EVYGQY
EDIT #2: Once you've got the codes, post them in the 5.4 section of the forum and people can help you there.
https://www.ford-trucks.com/forums/forum48/
Old Dec 3, 2011 | 08:11 AM
redrivergorge's Avatar
redrivergorge
He needs an obd 1 reader its a 94 with a 5.8
Old Dec 3, 2011 | 10:55 AM
Club Wagon's Avatar
Club Wagon
Agreed, Smokey6111 should heed his Check Engine Light & recover the Fault Codes & that a '94 is OBD1 system. However, his options are't limited to; buy a Fault Code Reader or "pay the dealer to check the codes".
Most auto parts stores are happy "to check codes" for free.
Old Dec 3, 2011 | 12:02 PM
pl77's Avatar
pl77
My bad, I didn't catch the year.
I've never had an auto parts store check codes; I didn't know they did that! I learn something new everyday...
Old Dec 5, 2011 | 04:17 PM
Smokey6111's Avatar
Smokey6111
I have tried to get the codes by going to a mechanic and a auto zone. They all said they didn't have the adapter or I don't have a adapter on the van to connect to to get the codes from because its old.
Old Dec 6, 2011 | 07:58 AM
subford's Avatar
subford
The code reader is only $22.00 at Amazon, O'Reilly auto parts also sells them:
Amazon.com: Equus 3145 Ford Digital Code Reader: Automotive
Here is your plug and no adapter needed:
Old Dec 6, 2011 | 01:23 PM
econolinemanor's Avatar
econolinemanor
A bad Temp (Sensor) or connector for the computer will do that, its not the same thing as a Temp (sender) for the IP gauge. It will stay on a cold start loop (high idle) forever untill the computer knows the engine is warming up!
Old Dec 6, 2011 | 03:14 PM
Smokey6111's Avatar
Smokey6111
Thank you, I will definitely have to look into buy one of those. This is just crazy all because it is older....lol
pappyfixit67
Oct 3, 2011 11:33 PM
MikeRizz
Jan 30, 2010 07:21 PM
hondaracer27
May 11, 2009 04:25 AM
97F250LD4X
1997 - 2003 F150
Mar 3, 2006 11:38 PM
strokeman
Aug 27, 2003 10:36 AM
