Bronco II Ford Bronco II
Codes
Old Jan 16, 2006 | 04:34 PM
Dragonfox13's Avatar
Dragonfox13
Exclamation Codes
I own a '89 4wd xlt and pulled codes today and was wondering what they meant
this is with the engine running
41
71
72
73
KoEo i got an 11
Old Jan 16, 2006 | 04:59 PM
OSin86's Avatar
OSin86
Here's what my book says:
41 - HEGO (HO2) sensor voltage low / system lean
71 - (This is a constant code not an KOEO) Idle tracking switch closed on pre-position
72 - MAP, MAF or BP sensor out of range during Dynamic Responce Test
73 - Insufficient Throttle Position change durring Dynamic Response Test
Looks like when you were supposed to pin the throttle to WOT you didn't go far enough. I'd run the test again before you start digging into anything.
Old Jan 16, 2006 | 05:35 PM
mrshorty's Avatar
mrshorty
As noted, KOER72 and KOER 73 are almost always operator error. KOER 41 (especially in the absence of a memory (CM) 41) could also be from not preheating the O2 sensor immediately prior to the KOER test. As noted, review KOER test protocol and repeat test before doing anything else.
kbf1961
Oct 17, 2015 10:05 PM
IM1096
Mar 29, 2007 09:02 PM
christoph2069
1983 - 2012 Ranger & B-Series
Aug 23, 2005 01:41 PM
y2kexc
18
Jul 29, 2005 08:04 PM
swunderle
Escape & Escape Hybrid
Nov 7, 2004 03:59 PM
