General Automotive Discussion
GMC problems
Old Jan 15, 2006 | 04:26 PM
Ford_Six's Avatar
Ford_Six
GMC problems
Not a Ford, but I have to make it run anyways. It's a 94 GMC W4 Forward (isuzu built) with a 350 and 4L80E. On Thursday or Friday, the driver came in complaining it lost third and fourth gears, it just had first and second. The other mechanic/driver took the truck out and confirmed it, brought it back, and shut it off. The truck has not been able to start since. It will crank all you want, no fire, no spark, no injector pulse. I put the code reader on it, all I got was a code 12, no reference pulse. I checked the ignition module, got a solid .5v ac out of the pickup coil when cranking, unplugged and cleansed every connector between the distributor and the computer, all with the same results. The only thing I can think of is the computer went, and that might explain the loss of third and fourth, maybe as a limp-home mode. Anybody have to deal with something like this, have any insight?
Old Jan 15, 2006 | 06:24 PM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
It's a shot in the dark but I'm thinking cam or crank position sensor and/or associated wiring. Might be nice to run the pinpoint diagnostics on these to rule them out.
Old Jan 15, 2006 | 10:55 PM
jake00's Avatar
jake00
the only insight I have is that I had the exact same truck in my delivery fleet except it was the isuzu we sold it this summer. it was a pos. I agree with cowboy
Old Jan 15, 2006 | 11:07 PM
Ford_Six's Avatar
Ford_Six
Would this have a crank position sensor? It has TBI and a distributor.
Old Jan 16, 2006 | 12:30 AM
pfogle's Avatar
pfogle
Jared what's the transmission doing?? Hitting third and freewheeling? The no start is probably a computer issue. Is it possible that the ignition module has puked? Just because it's within voltage specs doensn't mean it's working.
Old Jan 16, 2006 | 12:43 AM
CowboyBilly9Mile
Didn't know they were still using that in 94; with a distributor I wouldn't expect there to be a crank position sensor.
Old Jan 16, 2006 | 01:18 AM
Ford_Six's Avatar
Ford_Six
From what I was told, the transmission would shift from first to second, then hold. Not even an attempt to hit third or fourth. This thing is driving me nuts, it almost sounds like it went fail-safe, but it still had first gear, and had decent power. I had the ignition module tested at the parts store, they checked it at ambient, cold, and hot, it checked out ok.
Does the ignition module send a signal to the computer, or does the computer directly use the pickup signal to trigger the module? Does anybody know what wires these would be on the computer plug?
Old Jan 16, 2006 | 09:07 AM
KICK's Avatar
KICK
is the distributor turning??
maybe what drives the distributor isn't.
I dont think a 94 GM with throttle body had the fancy crank and cam position stuff on it, just depended on distributor to tell ECM where it was.
Old Jan 18, 2006 | 10:05 PM
Ford_Six's Avatar
Ford_Six
Made some progress on the thing today, it runs now but not very well, and won't start without a shot of carb cleaner or ether. The computer isn't firing the injectors while cranking, but once the key is at run it's ok. The idle is really high, it's probably got a vacuum leak, but I'm trying to fix one problem at a time. Fuel pressure is ok when the pump is on, but the regulator is leaking by after shutdown, it drops to nothing pretty quick. I deadheaded the pump with a gauge on it, and the check valve held. The regulator had a kit put in it, and still did the same thing, so I'm kinda at a loss on that.
Is there a wire that goes straight from the ignition switch start position to the computer, telling it to fire the injectors? Does the ignition module go into some sort of stand alone mode at this point?
fabmandelux
20
Aug 13, 2009 08:01 PM
Stone Mathews
Jul 25, 2008 10:59 AM
mugrb
1983 - 2012 Ranger & B-Series
13
Jun 11, 2008 10:53 PM
DMch
1997 - 2003 F150
17
Feb 28, 2008 06:39 PM
rodney21
1997 - 2003 F150
Sep 9, 2002 07:39 PM
