Ok heres the story i have a 1993 Ford flareside 302 5speed. I am under the procces of converting it to a mustang speed density wire harness. But There are 2 promblems i'am concerned with
1 how dose the ecm get turned on? When i turn the key how dose it know to go in to run mood per say.
2 Is this engine goign to run right with the speed density, is the cam going to be compatible with the engine ?
Reason: wrong title
Hey thanks for all the reaplys, but i have changed my strategy a little bit, i got a mass air sensor and a mass air ecm from ebay , and i'am no longer using the mustang harness.
