Would someone please explain why my truck runs great with the red tube disconneted from the wastegate with more than enough boost but when I hook up my 5th wheel trailer it runs better with the wastegate hooked back up. Thanks.
The general info on this board is that there is a turbo stall condition that occurs under load. The stall/surge is prevented by the wastegate, but removing it allows the boost to build faster under a no load condition.
It doesn't really eliminates the waste gate, but now only held down by spring pressure. It will still open eventually. The red tube which is connected to the selenoid, now does not activate it by pressure supplied by the red tube. By removing it, "eliminates" the waste gate.
So as long as i am under load this is to be expected, Is this where the wicked wheel would allow you too leave the tube unhooked and mostly eliminate the stall problem?
Thats what i have been hearing. I am waiting for a nice day so I can change mine out. Not sure if I'm going to pull the Turbo out or do it in the truck.
__________________
01 F250 7.3 PSD CC 4x4 Lariat Auto
Skyjacker 6" lift
35in BFG Tires
A.R.E Cap
Viper Alarm
K&N FIPK w/Filter wrap
3 Gauge A-Pillar
hpx mod, Preadator Tuner
4in Exhaust Turbo back
The WW is the cheapest effective device at controlling surge. The problem with the stock wastegate is the spring doesn't have enough tension and releases
drive pressure thru the wastegate to early causing the surge/flutter. Once u install the WW adjust the spring tension by shortening the length of the road
(clockwise turn with vicegrips). No more flutter...serious boost and better egt's.
I second PSNut's advice. I did exactly that and it completly cured the stall/flutter coming from the intake. I was getting it even with a stock tune. Now I can pull the hills using the Diablo Predator Tow/Haul tune and still no flutter. It'll pull 27 psi boost easy doing that. If I flip on the 10k mod the boost goes up to about 28-29 psi and then the WW can't keep up. It will begin to stall. I don't need that much to maintain speed on the hills so I never run it that way. I just did it once as an experiment.
Suffice it to say if you don't have any tunes beyond Tow/Haul while towing, the WW is all you need.
Why couldn't you just adjust the wastegate spring with out having to install the WW, or is it a combo of the WW and spring adjustments.
The later style factory intake wheel has a completly different fin design than the WW. It has a greater propensity to stall vs the WW which bites the air harder and doesn't stall as easily.
Here's a picture from Johnny8's gallery showing the difference. You can see that the WW fins are staggered.
Thanks Kwik, I can see the difference in the wheels.
I have noticed the same issue as Texas when towing with the wastegate un pluged. During my next tow I was planning on hooking it back to see the difference, but that wont be until spring time. I never noticed the flutter/surge with my stock box, but I did when I had the Nappa fiter, and I understand why that was. I have now moved to an AIS, and have not towed with it yet, and I'm sure flutter/surge is still there and the AIS will block out alot of the sound also.
My questions is what type of performance loss would I see towing with my wastegate hooked back up. IE loss of power, higher egt's.
I guess I'm thinking just hooking back up is the easy way to prevent the surge issues. Plus I'm not sure changing to the WW is some thing I can do it looks pretty tough for a guy who does not claim to be good with the wrenches, and has never spent the night at a Holiday inn.
Rich I honestly don't know what it would be like towing with the WG plugged back in - I've never done it. I don't know that plugging in the WG will help with your 75 HP chip. It'll easily spool the boost up at low rpm's. Try it and see what happens and get back to us. Then we all can know.
hey Rich to answer your question. when i was towing with the waste gate unplugged and the stall was way too much to handle I pulled over and hooked it back up andthat cured the problem. I now run it unplugged when I am not towing and it runs strong and when i start towing i plug it back up. I am running the HYPERTEC ON 3RD LEVEL which I think is only aroun maybe 50 hp at most . With the Kwik filter and the extra50hp and 4 in all the way it tows ok but as you know we all want that little extra. good luck
