Wastegate questions?
Old Jan 12, 2011 | 08:19 PM
plgebbia's Avatar
plgebbia
Truck: 2000 7.3L 130k stock
I posted about a month ago about this truck being low on power. Some of you may remember...
I unhooked the wastegate today (the red "vacuum" line) and it seemed to run somewhat better.
I then hooked the line to the air compressor in my shop and set the regulator to 10 psi. The wastgate is opening at less than 10 psi. Does this sound like the problem?
If so, Where can I get the wastegate solonoid? Ford says there is no part # for it
Thanks guys!
Old Jan 12, 2011 | 09:47 PM
orng1's Avatar
orng1
Try adjusting it.
Old Jan 12, 2011 | 10:29 PM
rbaker6336's Avatar
rbaker6336
As mentioned you can try adjusting the actuator rod to give it more pressure.The spring in mine was beyond hope at 115k miles
Your milage may vary
Old Jan 12, 2011 | 10:36 PM
orng1's Avatar
orng1
I disconnected the vac line on mine.
Old Jan 12, 2011 | 10:41 PM
Wildfire532FB's Avatar
Wildfire532FB
How do you adjust it?
Old Jan 12, 2011 | 10:45 PM
orng1's Avatar
orng1
Take it off of the flapper and twist it.
Old Jan 12, 2011 | 10:53 PM
cavitation's Avatar
cavitation
Here you go:
https://www.ford-trucks.com/forums/9...ent-video.html
https://www.ford-trucks.com/forums/9...en-towing.html
Old Jan 13, 2011 | 02:46 AM
JIA's Avatar
JIA
I just picked up a couple of items for my '02. Wastegate was one of them.
Old Jan 13, 2011 | 03:51 PM
plgebbia's Avatar
plgebbia
Thanks for the info guys. Do I need to plug the red vac line if it is unhooked?
Old Jan 13, 2011 | 03:54 PM
spdmpo's Avatar
spdmpo
Yes, but it's not a vacuum line, it's a pressure line! You can plug it, or shove it over one of the intercooler boot clamp studs.
Old Jan 13, 2011 | 04:10 PM
plgebbia's Avatar
plgebbia
Thanks! Yea wrong term for the line..... But you got the point....
Thanks again!
Old Jan 14, 2011 | 02:47 PM
aklim's Avatar
aklim
I thought the wastegate starts opening earlier? Some like the Big Head unit because it is mechanical and based off the exhaust pressure for opening. I like the Boostvalve myself since it only sends pressure to open the wastegate when it reaches set pressure that moves a check ball.
Old Jan 14, 2011 | 08:57 PM
plgebbia's Avatar
plgebbia
Thanks, It is running much better (way more power) now that I unhooked the WG. Customer said it pulls his empty gooseneck trailer better than it did driving just the truck before I uhooked the WG.
Old Jan 14, 2011 | 09:45 PM
orng1's Avatar
orng1
Good to hear, I put mine on the clamp stud too.
Old Jan 15, 2011 | 06:44 AM
Newfiestang50's Avatar
Newfiestang50
So there is no risk of doing any damage to the engine by unhooking the waste-gate actuator and plugging the red hose. I guess by doing this the actuator is always closed no matter what....correct?
