Propane?
Old Jan 15, 2006 | 05:35 AM
99F-250lova's Avatar
99F-250lova
Question Propane?
For all the psd owners! What are the upsides and downsides of converting your psd to run on propane?
Old Jan 15, 2006 | 05:44 AM
RubberDuck's Avatar
RubberDuck
The upside is if you can do that, you would be the first. The down side is it can't be done. I think you mean run WITH propane. There are lots of guys running it and having great results. The upside of that would be more power, downside is having to refill the tank. That's just my opinion.
Old Jan 15, 2006 | 05:53 AM
PSNut's Avatar
PSNut
Upside: big power adder.
Downside: egt increaser
Now that's about .02 worth.
Nut
Old Jan 15, 2006 | 09:10 AM
barebackjake's Avatar
barebackjake
actually the motor can be converted to run on LNG like alot of school busses, transit buses, trash trucks.....the conversion is EXPENSIVE. i know someone that does the conversions and the kit for the john deere motors that are getting used in school buses the kit and tank is about 10k. you get a cleaner burning fuel but you will burn more LNG than diesel and even though LNG is cheaper than diesel right now i think the price will come up also. and there are very limited LNG fueling stations. most of the places that use them in there fleet have there own filling station built at the yard.
propane injection i really like it on my truck, as long as its properly set it can add a bunch of horsepower without blowing up your motor. with good programming to go with the propane the egt increase is minimal but it does increase, your adding more fuel and burning more fuel. but i think its definately worth it.
Old Jan 15, 2006 | 11:08 AM
99F-250lova
How much does propane injection usually run for? Setup and everything?
Old Jan 15, 2006 | 12:30 PM
hllon4whls's Avatar
hllon4whls
The injection kit is about 8-900 without a tank. Of course you can use BBQ pit tanks in the bed if you want. The propane basically adds fuel to the engine. You burn diesel and propane at the same time. Bully dog has a system and MSD makes a new digital system that is available online at Jegs or probably other retailers.
You should monitor the EGT's if you chose to do propane injection. A larger exhaust will help as well.
I was all gung-ho on the idea of propane injection, but with a chip exhaust and gauges, you are looking about the same net result.
Old Jan 15, 2006 | 12:41 PM
99F-250lova
Yea, I think I am going to stick with getting a chip and gauges. I already have the 4" MBRP exhaust which I love of course! I was also thinking of getting an intercooler to lower my egt's.
Old Jan 15, 2006 | 04:47 PM
barebackjake
i run the powershot 2000 its the only VARIABLE vapor only system.
you will need a custom chip to properly run the propane
your truck should already have a ic on it.
