Trans Sensor
Old Jan 9, 2006 | 09:23 PM
NE MACHINERY's Avatar
NE MACHINERY
Trans Sensor
Where is the proper placement of the transmission sensor suppose to be??? I installed mine in the cooler line just before the cooler. How accurate is this? Should it be in the pan instead???
Old Jan 9, 2006 | 09:25 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
usually they will supply you with a proper fitting to fit in the hole. it is located in the top left corner (above the pan lip, but right next to it) closest to the driver's location. it is riht above the little plastic box hanging off the side of the transmission. at least that is where mine and alot of other people's are.
Old Jan 9, 2006 | 09:59 PM
jtharvey's Avatar
jtharvey
I think the pan is the optimal placement for it, but not everyone has the ability to get a bung welded into the pan. The place where strokin mentioned is most convenient. I have my trans temp sensor there too. In stock form, there's a small plug in that hole.
GCLL
6.7L Power Stroke Diesel
Dec 6, 2013 09:21 AM
stimm32
Mar 16, 2013 10:36 PM
vlietracer64
Nov 3, 2010 10:35 PM
Edmund
Mar 14, 2006 08:12 PM
