different ZF transmissions???
Old Jan 8, 2006 | 09:12 PM
mad scientist:p's Avatar
mad scientist:p
Question different ZF transmissions???
ok, i have a 94 f-250 4x4 w/ a 351 and a ZF 5 speed. the tranny i have has a internal slave cylinder...another great invention by ford! grrr! no offense but sometimes i wish some the engineers had to actually work on a truck so they would know how to design a easily maintainable truck! again i mean no offense to anyone who likes the "brilliant" ideas that ford has every once in a while.
i have to remove the tranny just to change the slave cylinder! but a guy i know has an about the same year f-350 (maybe a 95 or 96) 4x4 w/ a powerstroke. it also has the same tranny only the slave cylinder is external and from its looks the transfer case seems to be bigger. does anyone know if these trannys were only on the f-350s or were there some on the f-250s as well? i am dropping in a 354 perkins diesel here in a few weeks and was considering trying to find one of these external ZF transmissions...what are your thoughts???
Old Jan 8, 2006 | 09:29 PM
Popa Tim's Avatar
Popa Tim
I beleive there are 3 versions of the ZF and they are engine specific not F-series specific. I'm sure someone with more tranny knowledge will chime in.
Old Jan 8, 2006 | 09:41 PM
mad scientist:p
ok thanks...yes i hope someone else will help. since i am doing a radical engine swap i can use whatever tranny i want b/c i have to have a conversion plate machined out so i can bolt up a ford tranny to the combine diesel engine. drive shafts might be a problem though.
Old Jan 9, 2006 | 05:15 PM
handyman43358's Avatar
handyman43358
Tim is right, there are 3 different versions. One bolts up to small blocks and has an internal slave cylinder. The other is used behind the 460, and I also believe it has the internal slave cylinder. The other is used behind the diesel, and it's slave cylinder is external.
Old Jan 9, 2006 | 07:44 PM
mad scientist:p
ok thank you. so i need to find one out of a diesel then. ok i guess i'll have to see what i can find.
Old Jan 10, 2006 | 05:44 AM
RTM's Avatar
RTM
I have a 460 ZF and it's external.
Old Jan 10, 2006 | 08:50 AM
mad scientist:p
ok, thanks. so now i have to find one for a 460 or a diesel then.
Old Jan 10, 2006 | 05:34 PM
handyman43358
Thanks for clearin that up RTM. I wasn't 100% sure on that one.
Old Jan 10, 2006 | 06:54 PM
RTM's Avatar
RTM
I don't think the 460 came with an internal set up but I could be wrong. The few I have seen have been external.
Old Jun 7, 2006 | 02:16 AM
F350JOHN's Avatar
F350JOHN
There are two that I know of:
The ZF5-s42 manual that has an external slave cylinder (like in my 1992 F-350 w/460)
The ZF5-s47 manual that also has the external slave cylinder (like on my 1995 F-350 Powerstroke)
I hope this helps.
shanes66charger
Apr 26, 2014 08:42 AM
irhunter
Sep 13, 2011 09:44 AM
hillbillyk
Apr 29, 2011 10:55 PM
TreoWayne
Mar 2, 2009 07:18 PM
bubbaredneck
Aug 27, 2001 05:30 PM
