Service Engin Soon ????
Old Jan 6, 2006 | 08:06 PM
buddythomashou's Avatar
buddythomashou
My Expedition is a 2000 with 63k miles, runs great. I had a loose gas cap which caused the SERVICE ENGIN SOON to come on. I put the gas cap on properly and reset the indicator by disconnecting the positive battery cable. I reconnect it the SERVICE ENGIN SOON was off. It remained off for several days then came on. I went the whole routine again. This happen three times in about three weeks. The light came back on to day. I just came in from checking the gas cap, it seem find. During the period my gas mileage have gone to hell. Does anybody have a suggestion?
Old Jan 6, 2006 | 08:13 PM
ford390gashog's Avatar
ford390gashog
"by disconnecting the positive battery cable"
you never want to pull the + first. you always pull the negative.
Old Jan 7, 2006 | 12:33 AM
Racerguy's Avatar
Racerguy
Next time the Check Engine Light comes on you should take your truck and get it scanned for codes. Apparently Autozone will do that for free if you have one close by.
Rather than having them scan it and then sell you parts, I would write the code number down, not just the description of it, and post it here. Someone will be able to help diagnose it.
Old Jan 7, 2006 | 02:03 AM
AlfredB1979's Avatar
AlfredB1979
The only problem (can be big for some) is that you reset the EEC system, so when you want to scan the code, you just might have to wait a certain number (maybe a few dozen) of cycles (drives in the truck, basically) to get a good scan of the code you've got.
I did see a post in a Ranger forum about a guy who tried to get his vehicle inspected. He had a CE light, pulled the cable, reset the code, but the computer had not had enough cycles to allow the inspection test to pass. Ooops. Look for the EECV(?) fuse or relay in the underhood relay box and you'll know what I'm talking about, to some extent.
If you want to reset the computer PROPERLY, isolate it by pulling the ECU fuse in that same underhood box, then wait a minute and pop the fuse back in place.
Don't make it harder than you have to.
P.S. If the mpg's have gone to waste, then you might have an issue that is beyond being cured by a computer reset alone. Sucks to OBD2, eh?
Old Jan 8, 2006 | 11:59 PM
austinjorg's Avatar
austinjorg
AlfredB1979,
03/EB/5.4/2WD
Are you saying the proper way to reset the CPU is to remove the "ECU" fuse in the underhood fuse box wait a few and replace rather than disconnecting the negative cable?
Old Jan 10, 2006 | 04:46 PM
damone's Avatar
damone
Could be bad gas. Run it empty and go to a reputable station and fill with premium. Then if light comes on you will know it is not the gas.
Old Jan 11, 2006 | 08:39 AM
projectSHO89's Avatar
projectSHO89
It's not the gas and it's (obviously) not the gas cap.
Without the codes, you're just pissing time and money away.
Get it scanned.
Steve
Old Jan 12, 2006 | 07:17 AM
myEXisFAT's Avatar
myEXisFAT
If you have one AutoZone will scan it for free.
gogreenwave
Feb 13, 2015 09:10 AM
gocrymeariver
4 Cylinder Engines
Mar 9, 2009 11:18 PM
Stangfire
1997 - 2003 F150
Apr 23, 2008 01:52 PM
rmalvarez
Sep 28, 2003 02:05 PM
tdarden_f250
Modular V8 (4.6L, 5.4L)
Dec 29, 2002 02:33 PM
